Steering damper mounts
Started by MidgetMike, December 16, 2004, 09:54:39 PM
MidgetMike
What are some of the different ways you all have mounted your steering dampers with hysteer. I've seen on the spring plate, frame and pumkin. What mount have you used and why?  :turtle:
KYOTA
I mounted mine to the flipped spring plate using the stock stabilizer bracket that came off the front of the axle. I decided to mount mine here because the stabilizer is more paralell to the tie rod.
MidgetMike
I realy like that way, I had mine mounted to my frame it didn't follow the axle at all now I want something that is more parallel  :turtle: thanks
