Another noob question...
Started by h8z2luze, June 21, 2010, 12:43:55 PM
h8z2luze
So I am getting the 4wd power steering setup from a 88.  To use it do I have to just do it and crossover steering at the same time?  I cant drive much longer with this push pull crap on 35s lol.
gtoyonrocks
You shouldn't have push pull stuff unless someone did a solid axle conversion to you truck and about the power steering, you should be able to get any set up for an ifs toyota truck and it will bolt right up.
h8z2luze
Sorry I didnt mention my truck is a 82.
gtoyonrocks
Ok, I saw 88 and assumed your truck was an 88. If your planning to use the box from the 88 then yes you would need to convert your truck to cross over steering.
h8z2luze
I just want power steering lol.  I mean id like to do high steer when I can but if there is a way I can just get power steering somehow right now that would be sweet.
gtoyonrocks
Yea, you will have to get a power steering box from a solid axle truck.
h8z2luze
Ok well I guess ill have to wait for high steer then lol...  Noob question inside of a noob question...  Is high steer and crossover the same?
gtoyonrocks
I think I have a power steering box for you but I would have to look. I'll have to take a look but if I do I'll sell it for 50 bucks. It will bolt straight up to your truck. If you want it 50 plus shipping.
-Jake-
Quote from: h8z2luze on June 21, 2010, 05:27:43 PM
Yeah highsteer and crossover steering are the same thing
