toy AC
Started by toyman2, December 15, 2004, 09:27:49 PM
toyman2
does any one know where the vacume line for the idle up goes
so that when you turn the ac on the idle kicks up so as not to kill the moter
Marlin
Constant vacume from the intake mainafold is routed to the A/C vacume solinoid and then to the idle up vacume diapharm on the side of the carburator.
Marlin
toyman2
efi
vut what i found in a book is called VTVits like a one way diafram (sp)
