Does this sound like a t-stat? I GUESS NOT!
Started by BLUCRUZ, December 14, 2004, 05:07:52 PM
BLUCRUZ
Engine overheated on the way to work this am. Had it towed home cause I didn't want to deal with it. Radiator & everythjing is less than 10k miles old. Temp went all the way up & when I pulled over I couldn't see any water in the rad. Heater wasn't working so I I knew something was up.  No smell of coolant in the exhaust and no coolant in the oil, I just can't figure out where all the coolant went?? could the t-stst just be stuck shut???
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
ooooooohhhhhhhhhhhhhhhh    sounds like you popped a freeze plug,  did you check your antifreeze to see how cold it was good for,  i need more in my truck its good to 5 degrees, but needs to be lower i think
but alas,  look at the sides of your block for missing freezeplugs, :down:
Mike D
I was gonna say head gasket untill i saw that there was no smell of anti-freeze in the exhaust
yep its that time of year kiddies,  i have seen motors blow the freeze plugs and seen radiators pop at the seems because the tstat worked and didnt circulate the water and going down the road the rad got cold enough to freeze ,  bad bad boo boo
BLUCRUZ
Mike D
it sounds like a head gasket to me.... Mysterously disapearing water is there water dripping out the exhasut
BLUCRUZ
Quote from: Mike D on December 14, 2004, 06:14:43 PM
No, just the normal condensation taht goes away after a while. I was only down about a 1/2 gal of coolant, I ran the engine again a few minutes ago and it's building up huge amounts of pressure in the rad and upper hose. I pulled the plugs and they look ok too so I doubt it's a head gasket, I even unhooked my temp sensor on top of the t-stat housing and the guage just kept rising???
Mike D
have you done a rad flush recentially?
BLUCRUZ
Mike D
then just go and buy a t-stat they are under 10 bucks and a good assurance and if it don't work then thats one thing it isn't
BLUCRUZ
Quote from: Mike D on December 14, 2004, 06:27:50 PM
i'm letting it cool down now so I can pull it- I've just never seen one stick shut, usually they stick open. :ack:
Mike D
KYOTA
Mine was stuck shut getting hot and I replaced t-stat, all hoses flushed and filled with a 50/50 mix of coolant and now the temp needle sits about a 1/4 the way up from cold - perfect.
Mike D
BLUCRUZ
ok, t-stat is out, water was on stove and it didn't open till 240*, shut back up at 230*, I think that's it. it was boing over the overflow this morning when I shut it down so maybe I just lost more water than I thought before I stopped? Anyway this makes for good troubleshooting tech. I'll get a new toyota t-stat tomorrow, no more stant :pokinit:! :nonono:
" no more stant :pokinit:"  Stants suck bigtime!!!!  I've lost a motor to a nearly new stant, and had them fail right outa the box.  If you regularly flush your system and keep everything clean you should get tons of use out of a stock toy tstat,   Nate
brainlessfool
Quote from: Blucruz on December 14, 2004, 06:54:15 PM
AWWW ? does not water boil @ 212? you useing a presser cooker?
SWAMPER
Dude Stant does suck....good thing the one I got was stuck open
BLUCRUZ
Quote from: brainlessfool on December 14, 2004, 08:16:53 PM
Ah Yes Grasshopper! it was boiling for a quite a few minutes and I have a very accurate thermometer. i noticed it trying to open about 225 but it was fully open at 240. I'm also up about 3000ft so water boiling temp is a little higher like 218 or so.
SWAMPER
murray failsafe,   garranteed to stick open :bud:
brainlessfool
Well now I thought the higher you went the lower water boiled. :circle:
after you put the toy thermostat in, make sure you don't have any air bubbles this time :nonono:
fahrenheit 451
While you are at it check here for some good info:
http://4crawler.com/4x4/CheapTricks/index.shtml#Thermostat
There is an ancient TSB on it, for Corollas(?) with the 22re. Same problem on the 4Runners in '85. On my '85 4Runner, I just ripped out the jiggle valve to allow fluid to flow all the time since my local Toyota dealership didn't have the part in stock.
The number Roger shows was still valid when I checked.
BLUCRUZ
Well it's been a few days and I finally got ready to dive into it, right. Put in new toyota t-stat and no change-checked oil again and this time its dirty milk chocolate frothy diarrhea.  :mad:  Ok-Head Gasket right! NOT! :maddest: Somehow I'm pumping exhaust from the #4 cylinder into the cooling system and presurizing the system something fierce.  I havent got The Head off yet but I cant wait to see the crack that I'm sure is there! :rivers: This was a new ENGNBLDR head back in June, If the engine is shot i'm parting the rig out and bulding up my cruiser :hammerhead:
brainlessfool
SWAMPER
dosent the head have a 3 yr unlimited millege warranty? :headscratch:
sounds like a head gasket to me,  mine did the same thing ,   ran fine, then boom no water chocalate milk looking oil,  BLOWED HEADGASKET
reklund5
I've also seen 'em do this when the timing chain guide on the drivers side fails and the chain traintracks the cover.  It'll eat all the way into the coolant passage right behind the waterpump and make a hairline crack.  Sometimes the crankcase pressure is enough to pressurize the cooling system.  If you've got milkshake diarrhea in the oil  :crazy:  :reg: then I'd suspect headgasket and/or timing covere before cracked head.
Good luck!
Ryan
