AHHH Electrial probs
Started by DontStall Rockcrwl, December 13, 2004, 07:47:33 PM
DontStall Rockcrwl
my dd (89 toy pickup) all the sudden, my clock ashtray light, interior lights, and radio all went out. checked fuse and its good but replaced it anyways.. whats next?
You have all gotta be jealous how close i live to the 'Con
MidgetMike
Do you have a third brake light, you might have a short from a leak through that? Is there any water in your truck? Start checking the harness I think all those share 1 conector.
DontStall Rockcrwl
nope no 3rd brake light.. it was weird how it went out. i was just sitting in the parking lot at carls junior and i was putting my interior light bulb back in... and everything shorted out like 5 mins after that
reklund5
sounds like something opened...try removing the dome light alltogether (not just the bulb) and see what happens.  Maybe you have an open circuit somewhere.  (IF it was grounded I'd think it would've blown the fuse...)
Start with the last thing you tinkered with and undo it!
Ryan
mudaddict
Dont jsut check that fuse too check all ur fuses i blew the same fuse but it wasnt blown when i looked at it i had a different fuse blown and when i replaced if most of the stuff worked again so go through adn make sure all of ur fuses are good if they are just take apart the last thing u did like everyone else said and jsut go backwards.
I work At
All Pro Off Road
MidgetMike
check the fuses in the engine compartment  :dunno: mine always f&%*  me when searching for shorts.
DontStall Rockcrwl
fixed the problem today. thanks mike i did what you said.. i checked all the fuses on the interior, all good, so i went o the fuses under the hood. had a blown 15 amp fuse. so thanks man  :beerchug:
donkeykong
I hate electrical problems...I had 2 trucks that would not start for a week because of one wire  :tantrum:
