Fender Cuttin'
Started by solar86yota, April 04, 2010, 07:15:09 PM
solar86yota
I need some ideas for trimming the fenders on my second gen shortbed my tires are rubbin' like crazy! Pics PLz!!!Thanks
By the time I get the money for an SAS I'll be 65 at this rate!
bigarms23
what size tires you runnning
bigarms23
or something like this
<MIKE>
just keep cuttin' till it doesn't rub anymore. this is your chance to get artistic with it so just have some beer and let the creative juices flow thru your sawz all
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
87hillbillyoter
Quote from: Tacosupreme on April 04, 2010, 08:21:48 PM
haha for shure. all you gotta do :thumbs:
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
solar86yota
Quote from: bigarms23 on April 04, 2010, 07:42:05 PM
I'm only running 32' bfg muds and the front fenders rub like crazy.
Its my DD also, so I don't want it to look crappy.
zippo
If you see it, its for sale.
bigarms23
take 3inches out of the front fenders and start from there
superyota
move the front axle forward.  usually will take care of front end rubs with no trimming
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
MiniSimp
Quote from: bigarms23 on April 05, 2010, 02:34:22 PM
3" is good for 1" lift and 36" tires.
You may just have the wrong backspacing on your wheels.
Either way sounds like you need to cut or relocate.
This is cut 3" and axle moved forward 2" with a 1" lift.
solar86yota
Quote from: MiniSimp on April 05, 2010, 02:55:50 PM
I am running stock toyota 15x7 inch rims maybe this is part of the problem. Can I get away with cutting maybe 2"off the fenders? Also the truck in my avatar is my truck just for reference.
Snowtoy
Are the tires rubbing the front fenders or the body seam/pinch weld on the firewall?
If you do need to cut the fenders, you should only need to cut the bottom corners, not the whole fender.  However if you are concerned w/screwing it up your DD, your best options are as follows:
The cheapest would be to run a 2" body lift(should be under $100) from 4Crawler
The next cheapest would be to crank the t-bars and add a few leaves to the rear leaf springs, but that would give you a very stiff ride.  Figure about $125 for a set of used leaf springs, new center pins, u-bolts if necessary, and an alignment
Next option would be to run some 1.5" ball-joint spacers(can also get them from 4Crawler's site), and some 3" longer shackles in the rear to balance out the truck.  Figure about $2-400+ for the spacers, longer hackles, 4 new shocks upper/lower ball joints, and an alignment.
The other option would be to buy some Bushwacker cut-out fender flares, about $160/pair at 4wheelonline.com, or look for some used ones.  You cut the fenders to clear the taller/wider tires, the flares cover up the cuts and also provide tire coverage to keep you legal.
Dark Knight
Hey MiniSimp, what size wheels you got there? 15x8, 2.5" backspacing? Your truck is a big inspiration for my 84... thanks.
MiniSimp
Quote from: Dark Knight on April 06, 2010, 05:22:41 AM
15x8 2" + 1.5" spacers front and rear, 36x13.5 irok.
Dark Knight
MiniSimp
Quote from: solar86yota on April 05, 2010, 07:18:49 PM
You should be able to run that with no rubbing since it has the stock backspacing.
start by seeing where it rubs, trim a little, test again.
Yota-Freak
Tony, this weekend im paintin my bumper and we should cut the piss outta our fenders. ill try to get a hold of a angle grinder. i might buy one idk
Volcom
I'm trimmed about as much as MiniSimp.  I just followed the stock opening and enlarged it 3" all the way around.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
