Author Topic: Carrier Bearing  (Read 7823 times)
greg_k113
  • Turtle Points: -49
  • Male Posts: 224
  • Member since Feb '10
Carrier Bearing
« on: Apr 03, 2010, 06:29:09 PM »
Does anyone make a heavy duty carrier bearing I just replaced mine like a year ago and it's shot already. I got it from Autozone.
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: Carrier Bearing
« Reply #1 on: Apr 03, 2010, 07:25:50 PM »
A factory bearing.
That's you best bet unless you want to have a single piece driveline made.  They only difficulty there is you'll have to step up considerably in thickness of the tube, due to the length.
              -Ronald Reagan
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Carrier Bearing
« Reply #2 on: Apr 04, 2010, 02:38:15 PM »
The answer to your question is no, I looked. Then I went to a one-piece but with my style of wheel I kept bending them, no matter how thick walled they were. Therefore, I went back to a two-piece but I made a custom mount and a heavy-duty pillow block bearing. Been on there for some years with out a problem. However, my rig is trailered and sees very little street time.
greg_k113 [OP]
  • Male Posts: 224
Re: Carrier Bearing
« Reply #3 on: Apr 04, 2010, 03:36:47 PM »
What does a factory one cost? And what is the deatails of a pillow bearing and how do you do it?
wayne_l
  • Male Posts: 37
  • Member since Apr '09
Re: Carrier Bearing
« Reply #4 on: Apr 06, 2010, 07:32:56 PM »
whats the bearing pillow block part number you used i found like 50 diffrent styles to fit the shaft but not one i could mis align a little bit for better angle ..
I love my country ,but hate my goverment ...
OOPS
  • Male Posts: 2,561
Re: Carrier Bearing
« Reply #5 on: Apr 08, 2010, 01:55:38 PM »
I do not know the PN on the bearing. I just asked for a 1.5 H-D PB bearing. Do not really have a write-up on install so I will do the best I can.
Cut the horse collar and built a frame work out of 3 x .25 steel plate.
This is what the bearing looks like. This bearing has some misaligment built into it.
The bearing mounts to this bracket and slips inside the framework.
The bracket is only bolted into the framework with two bolts and allows for up and down and angle adjustment also.
Mods made to the d-shaft.
wayne_l
  • Male Posts: 37
Re: Carrier Bearing
« Reply #6 on: Apr 08, 2010, 06:50:57 PM »
interesting way for another mouse trap ,thanks for sharing the info .. with the ford v-8 mine dont last long ..
-Matt-
  • Turtle Points: -184
  • Male Posts: 1,010
  • Member since Jul '07
  • Full throttle Rollin steady
Re: Carrier Bearing
« Reply #7 on: Apr 08, 2010, 07:53:26 PM »
this is a great idea, i saw you post on pirate about this the other week. im going to be using your idea, and combining it with my own for when i built my truck. the stock setup is just not designed for anything aftermarket. mine get trashed all the time from just having a lifted tacoma, i cant imagine a stock one holding up at all in the rocks. did you have to add any other spacers or washers to the setup to get the yoke to fit right?
OOPS
  • Male Posts: 2,561
Re: Carrier Bearing
« Reply #8 on: Apr 08, 2010, 08:21:59 PM »
No.
85yoter
  • Turtle Points: 8
  • Male Posts: 96
  • Member since Mar '10
Re: Carrier Bearing
« Reply #9 on: Apr 08, 2010, 08:32:56 PM »
ditch that thing :wave: and get a one piece made    mine went in four months  :hammer:   it almost cost the same amount to get the one piece made as that    :pokinit: cost
-Matt-
  • Male Posts: 1,010
Re: Carrier Bearing
« Reply #10 on: Apr 08, 2010, 08:34:42 PM »
ya but did you have a stock support bearing or did you do something like opps made?
85yoter
  • Turtle Points: 8
  • Male Posts: 96
Re: Carrier Bearing
« Reply #11 on: Apr 08, 2010, 08:51:35 PM »
yeah i had stock     but why do all that?   no dual cases ?
greg_k113 [OP]
  • Male Posts: 224
Re: Carrier Bearing
« Reply #12 on: Apr 09, 2010, 04:46:01 AM »
how does a carrier bearing hold up to a single case with 4.7 gears? I imagine that wouldnt last long.
OOPS
  • Male Posts: 2,561
Re: Carrier Bearing
« Reply #13 on: Apr 09, 2010, 08:17:12 AM »
Yes I have duals. My d-shaft was still over five feet long and a 123 inch WB and I was bending them on the places I wheel like the Hammers. Maybe if I had been running a CV on the T-case it would not have been as bad. It was really not that much work. I have not bent a d-shaft or had a bearing issue since I did it five years ago.
85yoter
  • Turtle Points: 8
  • Male Posts: 96
Re: Carrier Bearing
« Reply #14 on: Apr 09, 2010, 10:35:25 AM »
that makes scence    i think I'm gunna run a cv at the t-case and see what happens   but if that dont work i will deffinently go with your setup   i just really dont want a extra bearing to worry about
-Matt-
  • Male Posts: 1,010
Re: Carrier Bearing
« Reply #15 on: Apr 09, 2010, 12:30:58 PM »
your still going tol have issues, doesn't matter whether you have a cv or not it will probably still going to go to :pokinit:, as long as your trucks lifted and not the stock ride height then might as well make something that works well. i have a cv and mine went out in 6 months.. im on my new one and it already has signs of going out. mike (rock yoat) on here also goes through them every 6 months. i know having a tacoma also plays a role in them going out faster since theres more power/torque.
85yoter
  • Turtle Points: 8
  • Male Posts: 96
Re: Carrier Bearing
« Reply #16 on: Apr 09, 2010, 12:52:12 PM »
yeah i just have a little 4 banger    im hoping after my cases are in that will shorten the rear enough
95toyrunner
  • Turtle Points: -124
  • Male Posts: 705
  • Member since Jun '07
  • Whaaaaaaaaaaa?!
Re: Carrier Bearing
« Reply #17 on: Apr 22, 2016, 02:51:32 PM »
MY NAME IS HOLDEN AND I LOVE SUBARU'S AND SWEATY MEN
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
Last post Apr 11, 2006, 10:27:42 PM
by 4.3 headache
Last post Oct 13, 2007, 09:03:05 PM
by Duffil
Last post Jan 27, 2008, 06:27:08 PM
by allbones
Last post Jul 31, 2008, 08:05:16 PM
by Phazertwo
Last post May 05, 2012, 09:35:24 AM
by OOPS
