Washington state rigs
Started by ZDP, March 23, 2010, 12:21:42 PM
gtoyonrocks
Very nice. My rig isn't from Washington but I'm orignally from out there. What part or Washington are you guys from?
tanabuse
#31
well im right in the puget sound area im right by everett
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
I'm originally from Yakima. I lived in thr Tri Cities area for a while but mostly Yakima. I've been in San Diego for about ten years now. I miss Washington but love it hear as well.
tanabuse
i bet its sweet down there. there is so much open country to just go wheel in. but up here flopp  u cant cross a creek with out a ticket its lame
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
It's hit or miss to tell you the truth. We do have a lot of wheeling but it seems like each year there is less and less. I like the fact that I'm fairly centrally located. There is a lot of really good wheeling that isn't to far away.
tanabuse
yeah thats gotta be nice but can i ask u about your propane set up  ive ben trying to run it for a while did u home brew ur set up or did u just buy it from got propane
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
I bought mine from gotpropane. It's sweet. I'm telling you it's the way to go. I don't think it would be to difficult to put it together your self but for the time and money that you would spend I think it would be better to buy the got propane set up. What do you want to know?
tanabuse
well just waht u told me so far. i have all ready tryed to put it together my self and i got it running / idel but i cant get my truck to drive on propane its wired oh well i think its a tuneing isue but oh well i think i might go mechanical multiport fuel injection with some vw parts it works well as for as ive seen
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
You should calll gotpropane.
tanabuse
well tryed that :mad:  they wont help u with any home brew setup at all. u have to but THEIR kit becase they know there kit in and out. i put mine together so they dont know :pokinit: about what i have oh well i will just bite the bullet i even from just the begining   i just asked then about one of the componets of the kit just so i could go buy it from impco but there were all like thats very rude to ask a company about its  systems and they told me nothing but " we only give tech support for OUR KITS "
oh well ill get it soon enuf
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
I see... I'm sorry. I could pretty easily copy the set up that they sold me but I would never reproduce it to sell or anything like that. It's pretty basic but it works great.
tanabuse
sall good man i bet it works grate my truck ran grate on propane but i got to get the carb tuned if i may ask what kind of tuneing did u do to ur set up or did u just buy it and install it and do u have any pixs?
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
i got a cuple questions about ur motor i see u are running a hybrid well could i get the specs im just wondering  cause i want to bild one i just have a 20 R with a weber  but i wanna run a 20 bottom end with a 83 22Re celica head  but which head gasket would i use? just asking for some input if u dont wanna talk about it thats cool whats funny is i have like tons of blocks heads and i have that whole 83 celica motor and wireing harness
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
Turning
Over after
Years
Of
Trail
Aabuse
gtoyonrocks
You didn't upset me. Why would you want to run the 20r lower end? I don't understand. I will take some pics tomorrow. I have a hand full of guys asking me questions wanting to see different things. I'll try and get to it before my sons birthday party tommorrow. I'm running 22r lower end which give you the double row timing set and the pop up pistons and I'm running an older 20r head. They have swirl port, I am running the one with out a fuel pump boss. I was told they flow better. I'm not sure if that is true or not. I went with the 22r valves and the aluminum rocker arms with an adjustable timing gear set and a mild cam. The truck actually works really well. The point to me was to build a performance 22r on a budget. You have to be careful trying to get a 22r to perform well because you can spend an arm and a leg. I wanted the higher compression to take advantage of the propane. Propane is 107 to 110 octane. I'm telling you this thing is sweet.  I want to say the motor cost less than a 1000 to build with everything. I hope this helps. If I was you I would honestly bight the bullet and just buy the gotpropane stuff. Oh and I'm running a factory 22r head gasket from Toyota... I think if you were to run a 22re head on a 20r it would require a lot of machining to make it right. You may be able to bolt a fuel injection set up off a 22r on the 20r head, or you could modify an intake to make it work and you would have to make a spot for the knock sensor but I'm pretty sure it's possible. I have taken a third gen fuel injection set up and bolted it to a 84 and prior head, it turned out great. I hope this helps.
tanabuse
i thought all 22r were single row timeing
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
and we can get off this tread pm me
Turning
Over after
Years
Of
Trail
Aabuse
FRANKENYOTA91
85 toy double extended cab pos wheeler bobby longs, welded front and rear, dual cases
89 4runner sas,  duals, the usual
81 toyota long box project
83 short box project
2001 Cummins 6 speed tow rig
mudmaster
You take that Evans Creek or Elbe?
Time to go wheelin!
FRANKENYOTA91
Ive taken it to evans a couple times and the guy that had it before me took it up there a bunch.
Nimyad
#50
Spokane Valley.
my first gen before it was stolen
my 3rd gen i got to replace it, havn't got to take it up yet though, have a lot of work to do so i only have poser pics
79toy20r
My 79 before it got stolen for the second time
and how I got it back and sits now
79toy20r
Yea there have been about 5 or 6 in the last couple months. I drove around for 12 hours all through town. All in all drove 280 miles and finally found it in some dudes front yard. They painted it, taped over my toyota axle truss, fixed my bent rear bumper, and put a canopy on it
Nimyad
Ya they've got to be connected. we looked everyday for 5-6 hours for a week, never even got a lead
79yota4x
i would post mine but i still cant figure out how to down size the pictures
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
79yota4x
79yota4x
