1984 Toyota Extended Cab Pickup FOR SALE
Started by iortechnology, March 14, 2010, 03:07:03 PM
iortechnology
1984 Extended Cab Toyota Pickup FOR SALE. The truck is located in Albuquerque, NM. For additional information not included here, send an email to [email protected] or call 505-803-1978.
- factory front solid axle
- sun roof
- SR5 trim package
- EFI 22RE motor conversion
- Air Conditioning
- 255K miles
- 266:1 low range gear ratio
- 37" tires
- 6" lift
- Premier Power Welder
- On-board hot water shower
- On-board air
AND MORE... see details below!
My wife and I used this truck as a mild to wild four wheel drive vehicle here in the southwest from 2006. As our family continues to grow however (just had number 2), it is time for us to move into a bigger vehicle. Rather than have this one fill up my garage, This truck was built with driveability in mind - we would do a trip to Moab, UT and be able to cruise at 75mph on the highway. When there we could do the hardest of the trails and then drive the truck back home. All in air conditioned comfort! Add the shower to the mix and my wife had little to complain about on even long remote trips.
This truck will be a shame to see go - it works fantastic on all trails that I've taken it on. Drove it to Rubicon 2006 and back home, all of the hardest trails in Colorado, Utah and Arizona. This truck is balanced just right with the installed components and the low gears. It's never left me disappointed.
The truck is a desert southwest pickup and is relatively rust free. There are a few little paint bubbles in the bed seams (pretty typical for these trucks) but they've never been enough to worry about. The front fenders have been opened up to allow for the 37" tires. Otherwise, the truck is straight and a real looker when the off-road dirt is cleaned off. See the attached pictures for proof.
I have most of the receipts from upgrades and maintenance from my ownership of this truck.
Feel free to shoot me an email at [email protected] for additional pictures or questions.
Looking for $12,000 for the truck OBO. You won't find a nicer and more complete truck that's ready to drive home, and hit any difficulty of trail along the way!
Rear Axle Details:
1988 rear axle (3in wider than stock)
Disc brake conversion with GM metric calipers
Stainless brake lines
Bilstein 5150 remote reservoir shocks
Detroit locker
5.29 differential gears
Relocated axle breather
Low-profile drain plugs
Front Axle Details:
3" aluminum spacers (to match rear axle width)
Aisin hubs with chromoly inners
Hi-steer conversion
FJ80 tie rod ends
Longfield 30-spline chromoly axles and birfields
Detroit EZ-locker
Transmission & Transfer Case(s) Details:
Toyota 5spd manual transmission
Dual transfer case adapter 2.73 gears up front and 4.7 gears in rear case
Twin stick shifter (for 2wd low range - disengage front end for tight turns)
Heavy duty shifter springs (rear case)
Marlin Crawler 3/8" dual transfer case skid plate
All-Pro transfer case disc parking brake
Marlin Crawler triple drilled output flange
Engine Compartment Details:
1988 22RE EFI engine swap from Toyota 4Runner
Block decked by 0.030" for increased compression
TRD camshaft
3-angle valve job on head
TRD header
Air conditioning
Premier Power Welder with 30 foot leads
R&M underhood hot water shower with passenger front hookups
FJ80 master cylinder (for rear disc brake conversion)
Optima Red Top battery
Flowmaster exhaust with catayltic converter (passes emissions test without mods)
Body & Chassis Details:
IFS power steering conversion
6 inch All-Pro suspension lift
High Angle Driveline heavy duty double cardan rear driveshaft
Heavy duty front double cardan driveshaft (DOM 1/4" wall tubing)
Bobbed bed to length of bed on 4door Tacomas
Softtopper canvas foldable topper
Marlin Crawler sliders
ExtremeAire 12V air compressor mounted under bed
2 gallon air tank with 120psi blow off valve and tailgate access
37x14.50R15 Toyo MT tires
Mickey Thompson Classic II 15x10" aluminum rims
Rear swing-out bumper for tires up to 37", adjustable to wider/narrower rim widths, LED license plate holder, LED 3rd brake light, D-rings, Hi-Lift jacking points, rubber rattle isolators, bottle opener, double safety opening latches, open latch for trail use
Rubber bed liner
Gear tie down points
Interior Details:
SR5 trim package (speedometer cluster has tachometer)
JVC El Kameleon in-dash DVD player with 3.5" display, blackout controls, iPod hookup in glove box, CD/DVD player, removable face plate
Bucket seats from 1988 Toyota 4Runner (motor donor truck)
Grant detachable steering wheel (for additional vehicle security)
Grant steering wheel
Windows tinted
Factory grey carpet still in place (for sound deadening)
Grey trim package
Sun/moon roof with removable cover panel
Rear window defroster
If you have any questions or would like to see pictures of ANYTHING, please send me an email at [email protected] or call 505-803-1978. Thanks!
1984 Extended Cab EFI Toyota, always a work in progress...
iortechnology
A back end picture.
iortechnology
Engine compartment shot
iortechnology
Passenger front fender shower hook up shot
iortechnology
Shower heat exchanger shot
iortechnology
Power welder shot
iortechnology
Rear air access and compressor under bed shots
iortechnology
Driveway shot and Colorado trail action.
iortechnology
And one more Colorado shot
AWESOME LOOKING TRUCK! HOPE YOU GET WHAT YOU WANT FOR IT
notyourmomslx450
-Jason
"Daily Destroyer"-'94 xtra cab, solid axle, longs super set, 5.29s, detroits, dual ultimate, 37" MTRs, bobbed 12", Gulf Coast Crawl Shop bumpers, custom dents :eek:
"The Anchor"-'97 LX450, OME J-springs & L-shocks, spring spacers, wheel spacers, 35" Super Swamper SSRs, ARB, rack, it's just getting started
SC4Runner
1966 FJ-40: SOA, smelly and soon to be running.
1996 4x4 4Runner : IFS lift, locked and topheavy!
Jakesteads
I like Toyota
85_4RNR
#13
:bowdown: Well taken care of truck  :thumbs:
I work a 2000 BMW 540i 6 speed
iortechnology
Quote from: notyourmomslx450 on March 14, 2010, 05:10:40 PM
looking for any trades?
Well I'm moving to a FZJ80 when this thing goes. If you have a 1997 FJ80 or LX450 then yeah I'm ready to talk!
iortechnology
And... as I said in the first post with the description, this thing is highway ready. I'm willing to drive it to the new owner if needed. Or of course the new owner can drive it home too. Thought I'd throw that in.
renegade84
dumb question but where did you find the tail lights i would like to find a set for my rig
PadawanYota_Stovy
 :bowdown: For a sweet ride .  :bowdown: a second one for a well detailed post and well written . This truck would be sweet ! Good luck on the sell . Whats with the on board shower ?  Very cool looking truck though .
Stats : 85 Toyota 22RE , 3" body lift, 32" wild country's, Duel Marlin, Lock rights front and rear, full inside cage.
I drive , I wheel , I crawl , I am Toyota
notyourmomslx450
Quote from: iortechnology on March 14, 2010, 08:44:40 PM
weeeeellllll......
It's got a brand new interior, too.  When Ike came through Texas, I was out of town.  During the storm, all the tree debris clogged up the sunroof drains and water got inside through the sunroof.  It's got a new headliner, brand new (from Toyota) front carpet, Mastercraft Baja RS seats, and a mastercraft bench is in the works for the rear.  The rest of the specs are in my sig line.  It's at the shop now getting a drain on the battery tracked down and getting a new evaporator and dryer for the A/C.
-Jason
iortechnology
Quote from: renegade84 on March 14, 2010, 08:56:27 PM
I think I found those on eBay. They are actually pretty sweet. The reverse lights are MUCH brighter than stock and it updates the back of the truck nicely.
iortechnology
Quote from: PadawanYota_Stovy on March 14, 2010, 10:49:33 PM
The on board shower is something people laugh about until they are around it. I was on Rubithon 06 and had some welding to do at Rubicon Springs. Most of the wagon drivers had the showers on their rigs, which I originally thought was dumb, but after welding and grinding all afternoon, I quickly changed my mind. Ordered my own when I got home - it was that awesome. Since then I have used it to extend trips in the backcountry (suddenly those cattle water troughs in the desert are much more useful) and having warm water for cleaning up dishes is a hidden perk. Add the ability to hose out dog filth from the bed, or clean up the windows/headlights/etc if the washer fluid is gone, and you have a pretty useful tool. One less thing for the ladies to complain about too "but I need to take a shower every morning...". Now they can!
iortechnology
Quote from: notyourmomslx450 on March 15, 2010, 08:17:46 AM
weeeeellllll......
Shoot me an email at [email protected] or give me a call 505-803-1978. I'm interested in seeing some more pictures of the LX450. We can do this off of the  thread.
- Brandon
iortechnology
Interior shots by request... first one is of the drivers side. Now the wood steering wheel... that's a kickback from my wife's car. We did a few long road trips and a wood wheel is about 100 times better than the stock one felt. Anyhow, the wheel is wood and has the Grant removable adapter on it so that you can unlock the wheel from the column for security.
iortechnology
iortechnology
iortechnology
iortechnology
iortechnology
Today in the driveway driver side.
iortechnology
Passenger side today in the driveway
notyourmomslx450
if you get a chance, could you put up some pics of the front axle setup?  does it have stock shock mounts or did you add knuckle ball gussets?
-Jason
