"These dusty roads ain't streets of goldBut I'm a happy right where I'm at"
hey on my wilson i mounted the base first, then the 10 inch shaft, then the spring, then the oil can, with the whip on top, and at freeway speeds it lays back about 5-10 degrees not bad i'd say on the trail it flops around like crazy though
bigmike how you do that with out doing the percentage thing
I'll build a 90° bracket and use 2 8mm bolts to attach it to the upper driverside corner of the back of the cab. I know the reception is best when you get the antenna up off the ground
Tennis balls make great bumpstops for the antenae.....Oh wait, use a racquet ball! Its blue to match the truck.
Started by Skinny_Pedal Parts Wanted
Started by BLACKDOG Parts Wanted
Started by toymech CB and HAM Radio Tech
Started by jimbo74 Toyota Pickup/4Runner Tech 1979-95
Started by KYOTA Parts For Sale
