Aug 03, 2024, 04:20:52 AM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Our classic Hot August Sale is back!
Save 10% site-wide!
Click for details
Vehicle Specific
Toyota Pickup/4Runner Tech 1979-95
(Moderators:
Cheesemaker
Willy Mammoth
Blingn
Topic:
Unhappy 22r
Pages: [
1
Go Down
Print
Author
Topic: Unhappy 22r (Read 2756 times)
locked 4x4
Crawler Guru
Turtle Points: 0
Member since Aug '09
Unhappy 22r
on:
Feb 26, 2010, 12:49:31 PM »
So the other day I was playing up in the snow. I was going up this hill and I was gettin on it pretty good and all of the sudden my truck starts to sputter and dies out. I didnt think it was a steep of enough hill flood the truck out but i backed down anyway. I tried to start it on flat ground and it died again and again and again. I found that If i got it started and held it so that the rpm was 3000 or more i could get the truck to move but it was still running rough. I drove it off the trail like that. It sounds like an old tractor just making a nasty putting sound. and if the rpm was below 3000 it would just dies. I checked the spark plugs and they was a nasty crusty tan color. Thought that might have something to do with is so on the way home i stopped and picked new plugs and spark plug wires and it helped but it is still running like crap. I checked both the coolent and oil and they were both normal. I feel like the truck was running hotter than normal even though the temp guage didnt say the truck was hot. I could smell the rubber mounts that hold up the egjaust melting a little bit. To get the truck to move at all I have to start it and rev the piss out of it while fethering the clutch and it still dies most of the time. Any Ideas???
Logged
axled89
The 2.5K Group
Turtle Points: 296
Member since Jan '09
Re: Unhappy 22r
Reply #1
on:
Feb 26, 2010, 12:58:53 PM »
fuel pump went weak, or maybe the fuel filter sucked some crap up and not letting enough fuel threw.
Logged
i love oregon wheelin.
locked 4x4
[OP]
Crawler Guru
Turtle Points: 0
Re: Unhappy 22r
Reply #2
on:
Feb 26, 2010, 01:49:40 PM »
I took a look and I can see fuel in the float bowl. Shouldnt it run good on that fuel before it needs more.
Logged
axled89
The 2.5K Group
Turtle Points: 296
Re: Unhappy 22r
Reply #3
on:
Feb 26, 2010, 06:04:16 PM »
yea i guess so.
Logged
brainlessfool
It's not my problem if you can't hear the voices too.
Gold Turtle Award
Turtle Points: 2730
Member since Jun '02
drive fast or the devil may get ya
Re: Unhappy 22r
Reply #4
on:
Feb 26, 2010, 06:42:31 PM »
cam jumped time?
dist. moved?
ign. useally craps out at high rpm if its weak.
same for a weak fuel flow.
I geass maybe if you sucked some junk into the main jet, butt it would still idle.
Logged
A good day working, that's just sick
Silver Turtle Award
Turtle Points: 7571
Member since May '07
Re: Unhappy 22r
Reply #5
on:
Feb 26, 2010, 07:22:16 PM »
Something stuck in the carbs needle valve
Pinch off the fuel line and run engine until it dies. Then unpinch.
With the float dropped because of empty fuel bowl, you should be able to flush out what's stuck in the needle valve.
Logged
22RE W56B
locked 4x4
[OP]
Crawler Guru
Turtle Points: 0
Re: Unhappy 22r
Reply #6
on:
Feb 26, 2010, 08:04:37 PM »
Thanks for the advise. If its not raining out tmrw i think ill try and figure it out. I was also thinking if i just drop a little gas in the carb it should run right for a second. That would tell me if its in the carb or something else.
Logged
Silver Turtle Award
Turtle Points: 7571
Re: Unhappy 22r
Reply #7
on:
Feb 26, 2010, 08:38:02 PM »
A stuck needle valve would make it run too rich, which is what your symptoms sound like.....
Logged
22RE W56B
1980 swap Under Construction
Rock Crawl'n
Turtle Points: 0
GET SOME
Re: Unhappy 22r
Reply #8
on:
Feb 27, 2010, 08:55:20 AM »
Hey last month i messed with this prob, turns on runs shitty at low rpms or dies ect its the ignighter .... 20rs are more frequent about have this issue well hope this might help you good luck...
Logged
locked 4x4
[OP]
Crawler Guru
Turtle Points: 0
Re: Unhappy 22r
Reply #9
on:
Feb 27, 2010, 12:35:04 PM »
how would u test if its the igniter??
Logged
Silver Turtle Award
Turtle Points: 7571
Re: Unhappy 22r
Reply #10
on:
Feb 27, 2010, 08:15:31 PM »
Quote from: locked 4x4 on Feb 27, 2010, 12:35:04 PM
Remove spark plug wire,put in mouth.
Hold spark plug you took it off and have someone start it up.................
Logged
22RE W56B
Rock Ninja
Gold Turtle Award
Turtle Points: 1452
Member since May '02
Solid axle Toys Rule ! ! !
Re: Unhappy 22r
Reply #11
on:
Feb 27, 2010, 09:38:23 PM »
check the vacuum lines sounds like the fuel cut solenoid is going bad or loose.
Logged
AR-TTORA founder
22R bored.060,
LCE stage II race cam
http://pure-gas.org/
32/36weber,
Marlin 1200 NON ceramic clutch, L52SHD+dualcase #2919, cable-locker, Yukon 5.29 gears, 35's, Allpro ebrake, front springs, and high steer, F150rears
RIP Nitro 9-29-07
I sure miss him
MarlinCrawlerInc
IS NOT
affiliated with TrailGear in any way
locked 4x4
[OP]
Crawler Guru
Turtle Points: 0
Re: Unhappy 22r
Reply #12
on:
Feb 27, 2010, 11:29:29 PM »
I dont think that there is a fuel line cut solenoid on the 22r motor.
Logged
axled89
The 2.5K Group
Turtle Points: 296
Re: Unhappy 22r
Reply #13
on:
Feb 28, 2010, 07:20:16 PM »
did you check the windsheild fluid??
Logged
locked 4x4
[OP]
Crawler Guru
Turtle Points: 0
Re: Unhappy 22r
Reply #14
on:
Feb 28, 2010, 10:58:43 PM »
Took the carb apart today and put it back together. Fixed the problem
Logged
Pages: [
1
Go Up
Print
Vehicle Specific
(Moderators:
Cheesemaker
Willy Mammoth
Blingn
Topic:
Unhappy 22r
