NEED STUDS!
Started by 95TacoTruck, May 02, 2003, 01:38:00 AM
95TacoTruck
:help: Well I just got my header from LC engineering, and I am pleased with the look, but I thought it came with the studs and nuts  to install it.  Does anyone know where I can get studs and nuts here in Freshole or should I order the kit from LC.  I could go to the dealer and get regular exhaust manifold studs and nuts but I don't know if I need something special.
95 Tacoma Extra cab, many mods to come........
5spd
#1
Just go to your local parts house and get some replacement studs...like true value hardware or Homedepot, pepboys ect...nothing special overall, they even have longer ones if the flange is thicker, they are the black studs....
84runner
#2
That would work but then you end up with a off sized nut like a 15mm if you go metric, and a standard if you don't. Just something that might concern you. And LC has a stud kit.
