95 T-100 build ground up
Started by yotaneck13, February 24, 2010, 07:07:16 PM
yotaneck13
ok i got a 95 t100 that i did a horiblt sas on it last year so im tearin it down to frame and starting over  here it goes someone is gonna laugh at the pics i cant believe they havent surfaced on the discrace thred yet
TO DO LIST:
Grind all ifs bracket off
Grind all rust off of frame
Repaint entire frame
Build motor mounts
Fab front spring hangers
fab front shakel hangers
fab switch panel in the fold down armrest compartment
Fab roll bar
Fab guage panel and relocate heater panel
Cut the rear portion of roof for topless
make doors removable
raise rear seats to clear speaker box
bob bed
cut rear frame locate fuel cell in bed
re build dorpanels
manuel windows and locks
fix rear lift (i dont wany blocks)
drop shakels in rear
Run brake lines
run fuel lines
Fab steering? no clue yet how last time was horrible
wiring for switch panel
Roll bar in bed with lights
Instal front vizor with lights
rear disk conversion
Have rear drive shaft made
pinion angles
dual cases
fix front spring pack
cold air intake
16inch beaklocks
new tires
fab front and rear bumpers with winch mount on front
dual batteries under rear seat
Convert ac pump to onboard air
New gearing with arb f and r
rear ends? have 10bolt? not sure have acess to dodge 1/2 ton whats everyone runnin
thegoofster21
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
yotaneck13
here it was when i got it and after the 2inbody was installed with 33's
yotaneck13
here is the truck goin to get the manual tranny at my uncles sorry i didnt take anypic of the tranny swap
thegoofster21
jmoffroad.com
yotaneck13
the first sas i did (didnt turn out too well)
yotaneck13
ok what about the fornt axel what do you recomend?
yotaneck13
first time out with first sas got stuck only had 2wd and bald 4deees my rear pinion angle on the 10bolt was horible i brokt a ujoint on the dshaft when i got in it so we had to get a semi and pull me out
yotaneck13
here is the starting of the second sas more pic i have to get on the com tho here is a few...we got the cab stuck under my garage door tryn to get it out
yotaneck13
i havent really been able to touch the truck since saturday as a metal shaving from my grinder got lodged in my eye had it removed and ground today but i still only have 45% vision in my left eye it sucks...so much for my 50$ nemesis saftey glasses haha but get this my auto insurance covered the surgery and my perscription bc i was workin on the truck haha
thegoofster21
just use a dana 44 out of a chevy
jmoffroad.com
89sastoyo
I wouldn't waste the time with a 44. If it were me I would just buy a 60 and call it a day. Ha I don't even know are tundra's driver or pass side drop? If passenger 60s are a dime a dozen out of new dodge's and fords. If passenger there a little more expensive but the swap will be the same as a 44 the axle will just cost more itself. I would run a 14 bolt or 70 rear you could get away with a 60 but both the other options are cheap and really strong. If you want to rock a 44 make sure its a 3/4 44 with  8 lug outers they have stronger shafts from the factory.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
yotaneck13
Quote from: 89sastoyo on February 24, 2010, 10:44:52 PM
so your saying dont even run the toyota rear then?
toytank
there  are lots of options id say if you run a toy rear then use  a chevy 44 it keeps your bolt pattern the same and it just as strong as your rear and cost effective.
however if you have a little money to spend  get a front 60 , and then i would run a rear 60 , dana 70 is a waste of time your gaining nothing over a 60 . the 14 bolt is stronger and you would most likly never break it ,but you loose alot of ground clearance. im not a big fan of the 14bolt everyone i know who put one in has since removed it. i know ill catch hell off that last statement but it is what it is!! good luck im looking forward to your build not to many 100's running around built.
old and sqeaky but she goes
Rocksnail
Would love to see a T100 on tons. That would look so sweet. if you go that way. i would do 60 front  only option. and for the rear you get a bigger option. D60 , 14bolt or D70. i would go with the 70 , but what ever you can find will work. just make sure there 30spline. and not a big 19 spline ( found in d60 rears)  If you want to stick with yota, Then use your rear axle and and pick up a toy front. or if the $$$$$$ is there get a diamond. If your hart iis set on a D44. then do it. But by the time you build one of them, you could have bought a D60.
Really it all comes down to what you want out of your rig. what kind of wheeling? tire size? do you DD it or it a trailer queen? All of theses are things to think about when you are building your rig. Anyway you go. im watching this. have always wanted a T100
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
yotaneck13
sounds like im lookn for a set of 60's with the front pass drop then i was wanting to dd it but not all the time jus to local trails an stuff but well see
yotaneck13
cupple more pics i can see better now so i should beable to get the rest of the frame grinded down ans sanded for paint  these are the tires i had to use flattened to fit it in my garage  and almost gutted then completly gutted then the inside pic of the cab stuck with kyle still holdin it then my gf ashlee grindin away got the motor pulled front axel removed cut that bulky front crossmember out that i had put in
yotaneck13
 another of the front with out a crossmember then the new one installed and finished then a pic ashlee took of me welding that i thought looked cool  then the motor mounts finushed with out the torsion bar mounts making them look bulky then the rear portion of the frame cut off   and the switch panel in the armrest mocked up
yotaneck13
Check out my parts thread i need to sell em to get stuff for my build  let me kno if anyone needs anything thanks, Cullin
http://board.marlincrawler.com/index.php?topic=67476
yotaneck13
heres my old cross over steering haha this was before i found marlin tho
89sastoyo
im just not a fan of 60 rears lol they work good the one advantage of a dana 70 rear over the 14 bolt and 60 is you can run lower gears a lot lower gears so it would be daily driveable on bigg tires. I would just do some reasearch go look on pirate4x4.com and check out what people are doing over there. I know there are a lot of builds on marlin but pirate has a lot of tech and if your just search threw stuff theres information everywhere.
92 2wd DD
first gen cab
IronClad
No they are the same shafts.  sometimes you just find the light duty 1/2ton 44's that have the pinner neck down the entire length of the shaft
Annihilation  Fabrication
Do you need a Hammer?
yotaneck13
what about dodge like a 75 or 6  1/2 ton rears ?
89sastoyo
Quote from: IronClad on February 25, 2010, 02:24:32 PM
gotcha yeah cause my buddy has the big hub 44 on his chevy but the u joint was bad and they guy gave him some shafts out of a half ton 44 and they were the small ones and looked super easy to break lol.
92 2wd DD
first gen cab
89sastoyo
Quote from: yotaneck13 on February 25, 2010, 02:43:06 PM
6 1/2 ton? That pumpkin is probably what like 35 inches around??? I'm not to sure what it would look like but if its what I think it is I would steer clear just go with a dana 60 14 bolt or dana 70 there all heap 14 bolts are a dime a dozen like 150 bucks all day. 60sare cheaper/
92 2wd DD
first gen cab
yotaneck13
yotaneck13
headn out to the garage i got the frame painted from the middle cabmounts foward last night but it started snowin idk what ill get done to day mabye finish the switch panel in the arm rest until the snow lets up
yotaneck13
ok so i def cant run the 10bolt so i need to sell it or trade for a 60 with pass side dif
yotaneck13
got 3/4 of the trame prepped and painted to day and the motor mounts are complete
yotaneck13
TO DO LIST:
Grind all ifs bracket off done!
Build motor mounts   done!
Fab roll bar
Fab guage panel and relocate heater panel-need guages
bob bed
cut rear frame -done!
locate fuel cell in bed-need
re build dorpanels
fix rear lift (i dont want any blocks)-need f150 or 63"chevy
drop shakels in rear-need
Run brake lines -need
run fuel lines-need
Have rear drive shaft made -need
pinion angles
dual cases
fix front spring pack not using 3/4 ton springs
cold air intake -need
16inch beaklocks- need
new tires-need
gonna run d60 f and r - need
