Have Issues with your EFI? Swap this Intake/Carb on and go back Carb. Simple and reliable. Swapping on a Propane Setup? You'll need a Early intake. and Carb base for your propane swap. Comes with EVERYTHING to swap it on and get ya going.
Carb and Intake came off an 87 Non-EFI Truck, ran it all summer. Ran great on my rebuild 22r. Needs a choke coil (don't know the tech name). Had the carb rebuilt by a local shop.
Comes with:
Air Filter Assy.
Throttle cable.
EGR Block off Plate. (The one on the Intake. Could make you one for the Block if needed.)
Ignitor/Coil
Distributer, cab and wires. (You can't use your Stock Distributer if you have a EFI Setup. Computer controls the timing advance.) The Distributer is setup for One vacuum line.
NO SMOG Equipment included, I removed the stuff along time ago, I don't have smog in my area want wanted to clean up the engine bay. Also every vacuum hose was removed related to the smog equipment. You may also need to block off plates for your manifold.
$150 + Shipping. If your In colorado I have family that drives to denver every once and awhile!
Going to clean everything up before bought. Sorry for the blurry pics lol.
![](http://img43.imageshack.us/img43/5632/dsc00240resized.jpg)
![](http://img691.imageshack.us/img691/8138/dsc00239resized.jpg)
