Author Topic: Flopped my truck  (Read 2407 times)
smitty9902
  • Turtle Points: 31
  • Male Posts: 88
  • Member since Nov '08
Flopped my truck
« on: Feb 20, 2010, 01:36:02 PM »
i flopped my 4runner and it was on its side for about a hour. i limmped it home and it has sat in my driveway for two days now. i changed the spark plugs but it still wont idel. it will fire right up no problem and idel for 5 sec and then pudder out. why? can anyone help me out? :dunno:
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
Re: Flopped my truck
« Reply #1 on: Feb 20, 2010, 02:21:49 PM »
Go drive the hell outta it. It pry has a little oil in the intake. Thats why you gotta get them flipped over fast.
91 Toyota High pinions f&r.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #2 on: Feb 20, 2010, 05:44:43 PM »
could of dislodged some crap in the fuel tank too.....
Those are some huge welds!
Tillamook, OR
timmaytoyota
  • Member since Oct '08
« Reply #3 on: Feb 23, 2010, 12:40:40 PM »
check ground wires could have knocked somehing loose somewhere :crossed:
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #4 on: Feb 23, 2010, 12:42:25 PM »
does it pour smoke out the exhaust?
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
smitty9902 [OP]
  • Turtle Points: 31
  • Male Posts: 88
« Reply #5 on: Feb 23, 2010, 09:47:03 PM »
doesnt anymore it did when i first fired it  up
swapped89
  • Male Posts: 1,221
« Reply #6 on: Feb 25, 2010, 12:39:46 PM »
Oil might have poured into the distributor cap making bad contacts or maybe even after you changed the plugs there still might have been enough oil in the cylinders or intake to foul your new plugs.
When I rolled my truck it was upside down for quite a while. I had to pull all the spark plugs Squirted carb cleaner in the cylinders and turned the motor over without the plugs in, to clean the cylinders out. Then i replaced the plugs and changed the oil. Somehow my distributor cap got oil in it also. Just cleanned it out with some stuff for electrical that was like "brake clean"
hope that helps.
what motor/ truck do you have?
smitty9902 [OP]
  • Turtle Points: 31
  • Male Posts: 88
« Reply #7 on: Feb 28, 2010, 04:11:41 PM »
86 4runner 22re
swapped89
  • Male Posts: 1,221
« Reply #8 on: Feb 28, 2010, 07:52:46 PM »
have you got it runnin better yet?
Napolian
  • Member since Sep '07
« Reply #9 on: Mar 01, 2010, 09:12:58 AM »
got any picks of the roll
smitty9902 [OP]
  • Turtle Points: 31
  • Male Posts: 88
« Reply #10 on: Mar 01, 2010, 07:54:11 PM »
ya she runs fine on the road. the other day i put in it 4 and the first little incline it puttered out and died. 4 high and low do the same thing and when i put it back in 2 it runs champ.when i was feathering the gas to keep it running i could hear the computer turnin on and off. so i dont no what that is now?
swapped89
  • Male Posts: 1,221
« Reply #11 on: Mar 04, 2010, 12:36:48 PM »
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
« Reply #12 on: Mar 04, 2010, 05:18:50 PM »
how bad is the damage?
smitty9902 [OP]
  • Turtle Points: 31
  • Male Posts: 88
« Reply #13 on: Mar 04, 2010, 07:14:51 PM »
can anyone actually help and not just want to see pics haha. the damage wasnt bad at all. as i said i only flopped it didnt roll it   ;)
-Matt-
  • Turtle Points: -184
  • Male Posts: 1,010
  • Full throttle Rollin steady
« Reply #14 on: Mar 04, 2010, 07:22:14 PM »
a long time ago i rolled by buddies runner (22re) when it rolled the motor moved enough to crack the rubber tube that hooks right to the intake, it did vary similar things to what you stated. 4lo or going up a hit is the worse. basically the crack was at the bottom of the rubber tube and opened up once there was torque on the motor. (like going up hill or 4low). but since it was pretty much closed when there was no pressure on anything driving a flat road or just idling was fine. take it off and check it out.. may be your problem.
smitty9902 [OP]
  • Turtle Points: 31
  • Male Posts: 88
« Reply #15 on: Mar 04, 2010, 07:39:43 PM »
my intake house did break off too. i never thought of that but it makes sence i will get a new one.
thanks matt
Last post Apr 29, 2005, 04:08:10 PM
by donkeykong
Last post Jun 18, 2007, 11:02:29 PM
by fatt_matt
Last post Mar 19, 2007, 06:30:12 PM
by BLACKDOG
Last post May 16, 2007, 10:53:57 AM
by dirtchicken
Last post Mar 15, 2009, 07:18:00 PM
by Birfailed
