Author Topic: Short 5 spd trans  (Read 2980 times)
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Short 5 spd trans
« on: Nov 29, 2004, 05:17:24 PM »
How long is the shortest 5 spd trans with the aluminum bell housing? Or are there any custom tail shafts to shorten the trans?
here is a picture of my trans and transfer case. If you could get the spline on the tail shaft up against the fith gear and use a short coller you could loose 4" or so.
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
Re: Short 5 spd trans
« Reply #1 on: Nov 29, 2004, 07:15:48 PM »
all the 5 speeds with a removable bellhousing are about the same length.  the only shorter toyota 4x4 tranny with a removable bellhousing is the L43 that was used in '79 and '80 trucks, it's 4" shorter alltogether than an aluminum 5 speed.  i believe the case itself is only about 8" long or so, but it has a long tailhousing adapter since it's originally a light duty 2wd tranny
here's some more info: http://www.marlincrawler.com/l43_trans.html
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #2 on: Nov 29, 2004, 07:23:08 PM »
Thanks, but I already saw that. I was going to use the early cast iron 5spd, but I have to be able to weld on the bell housing. Long story, starter is on the wrong side for my needs.
I wounder if there is a shop that can make up a new tail shaft that has the spline next to the 5th gear?
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #3 on: Nov 30, 2004, 12:08:26 AM »
Hey that's a good idea, but it might cost a bit. You would need a shaft and a new tail housing. Can't do billet that size because it would cost a fortune, and for cast it will require a new mold to be created which is a steep begining cost. Profits wouldnt be seen until at least the first hundred or so were sold..
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #4 on: Nov 30, 2004, 03:29:08 AM »
If you could do the shaft, I could do the tail housing. I have done some casting, its not too hard. You just need to make a styrofoam mold and pack it in sand, then heat the aluminum and pour. Now who can make a new shaft that won't be soft and break?
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #5 on: Nov 30, 2004, 04:23:22 AM »
I have an old cast iron 5spd I will take apart to night to see how close the shafts are. I will post back after finding out what I come up with.
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #6 on: Nov 30, 2004, 06:24:57 PM »
 :dancing:  :cheer:  :hyper:  :spin:  :crazyhappy:  :party:  :egyptian:
Ok, now that's said. Whooo Hooo, I found the tail shaft in the old cast iron 5spd will interchange with the aluminum 5spd.
All that is needed now is a short tail housing.
Well back to work, time to bring out the sawsall again.
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #7 on: Nov 30, 2004, 08:14:12 PM »
I just put the trans back together and it is 33 1/2" from the bell housing to the output flange on the transfer case. Thats 5" shorter than before. It looks like the shifter shaft may be a tight fit, but I will work on that later.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #8 on: Nov 30, 2004, 10:14:54 PM »
Great job  :_order:
This is a very interesting project.
Since the G 52/54 is a lengthen L52 type transmission, this is all but a factory conversion.
Getting it to shift is another issue.
The rear housing will need to be cut and rewelded. I have many housings in stock. Please let me know if you need any extra parts.
I have been putting the improved G54 gear set in the shorter cast iron housing but have never considered putting the shorter L output shaft in the longer G52/54 trans.
As soon as I can find some time, I will look at the linkage issuse.
Marlin
Willy Mammoth [OP]
  • Male Posts: 4,252
« Reply #9 on: Dec 01, 2004, 04:05:32 AM »
Thank you Marlin for your response on this idea. :respect:
 I was sweating having a 12" rear drive shaft and had to do somthing. If it wasn't for using a diesel engine with the starter on the wrong side I would have just used the cast iron trans.
 I am looking at cutting the tail shaft housing down and welding it back together. There will be only about 1" for the shifter shaft to slide back, but I am thinking of drilling a hole in the transfercase to allow the shaft to move back enough to work properly without comming in contact with the gear set.
More pictures to come as I progress.
Mark
Last post Aug 29, 2002, 06:52:06 AM
by 90TOYPU
Last post Jul 18, 2004, 01:41:24 PM
by WHITE_TRASH
Last post Oct 08, 2004, 05:30:01 AM
by trailrat
Last post Nov 09, 2004, 08:33:09 AM
by MidgetMike
Last post Dec 06, 2005, 07:51:33 PM
by swillbuilt400
