AC compressor removal??
Started by 1990GT50, January 27, 2010, 04:34:09 PM
1990GT50
Hey I wanted to remove my ac compressor on my 85 yota. Its currently uncharged and not hooked up to the belt system so it looks like just a matter or bolt removal. My question is wheather I can remove the compressor along with the discharge and compression tubes without coolant going anywhere, etc??? I want to remove the line coming from the top of the radiator on the passenger side to the compressor and the line that runs compressor to firewall. Is this ok or a no-go?
zippo
it should just unbolt. You can also remove the dryer, and the ac radiator. Make sure you plug the holes going into the cab. Incase you ever want to use it again
If you see it, its for sale.
boneyard customs
Dont remove it! Air Compressor it. Add a tank, A switch from grandads air compessor and hose and go wheeling..........
4RunnerChevy
Quote from: boneyard customs on December 29, 2010, 08:24:04 PM
:think:
emsvitil
Without an oil source, you'll eventually destroy the compressor
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
boneyard customs
I carry some extra oil always, just add a little before every use.
I wonder how many people drain their shop air compessors daily?
emsvitil
Except for York compressors which have a oil sump, the lubrication of AC compressors depend on the oil in the system circulating........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
boneyard customs
I have a york. (not installed) and the thing is massive.
4RunnerChevy
I run a Harrison AC compressor and I put an oiler on the intake.  Thing puts out air like nobodies business, on at 90 and off at 130.
4LoRunner
i kept mine and used it for my arb  :biggthumpup: and to air up and use power tools works great, just gotta remember to keep them oiled or they will  :flamer: up
Sas'd '86 4Runner, 22RE-T, 4.88s, Dual Stock T-Cases, Locked F/R, 35" MTR's.
http://board.marlincrawler.com/index.php?topic=55751.0
yoshaleng
Why do you want to remove it for? Turn it into onboard air!
