22re help
Started by 4X4U, May 20, 2003, 06:02:01 PM
vikingsven
#30
Sounds almost like it isn't getting fuel. Check the filter. I suppose it could be the tps, but again, start with easy, less expensive things first. You are getting closer.
 :chug:
drybone
#31
Did you take the tps off the manifold to let's say clean it????, I pulled mine off and I had to take it to the dealer to get them to set it right again, Pain inzee butt!!!  I need more info about what your motor is doing and not doing.......
Not just another ROck KRAwler.
Ever been to Dry Bone Falls.
4X4U
#32
i checked all the vacuum lines and I don't think any are loose.  I think one of the cylinders might be missing.  It's running really rough.  i can't get the timing set because it's running so rough.
84runner
#33
Well just keep throwing parts at it like a pitcher.  Just kidding, u could get it diagnosed for about $80 at the dealer
4X4U
#34
I fixed it today.  One of the injectors wasn't seated properly and air was leaking around it.  I Drove it around a little and i think everything is ok.  Needs a little fine tuning cause it hesitates just a little.  Thanks to everyone for all your help!
vikingsven
#35
Right on...Good job  :thumb: :chug: :beer: :chug: :beer:
BlueRidge2016
1980 Toyota Hilux, 5.0L 302 V8, Mod in progress: Dana 60 Rear Axle w/ 4:88 & ARB Locker's (It's no Rock Crawler, but it's a BLAST to :driving:)
