80 first gen project
Started by tanabuse, January 14, 2010, 09:26:44 AM
tanabuse
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
here are pixs  pix 1 is my drivers side  pix two is passenger and pix 3 is my budys drivers side view of crossmember hight his is much lower than mine
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
Quote from: 83crawler12 on January 21, 2010, 10:54:56 AM
you have a flat belly
so i guess its not flat but its close haven't got hung up on n e thing yet
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
me and him are bolth running FROR x member same thing  but he as no body lift.  Oh and here are pis of motor lift  blocks i got from 4 cralwer off road .com
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
is that all did i cover what you were gonna cover lol
Quote from: 83crawler12 on January 21, 2010, 10:42:12 AM
i can point out more if you want? :_order:
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
#37
so i went wheeling at the same place where i blew out my crawl box on the 26th of december. walker valley ORV park. I had a ton of fun there.  here are some pix. good thing i called my good buddy in his jeep. Because if we got stuck any where i know he would help us out thats wheeler code. and on that note this guy is a grate guy he would drag you down the trail upside down if needed. we only saw 6 trucks yesterday us three looking to be the most modifyed. it was nice  to be wheeling with one of the biggest bugys here in WA state those tires are 49'' iroks by 22'wide   :drooling: hes running all d60 dulley with the dulley wheel spacers still on  that thing is like a tank
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
#38
here are the last of them
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well iv'e ben playing around with the idea of on bord air so i got it done. i used a motorcraft ac compressor of a 76 ford truck its like the same thing as a york it has an internal oil reservoir  its grate setup you can even run inpact tools off of it. its sweet oh and i found out a deal on a motor that was ran on propane so you dont need to set up a big oiling setup running around under ypur hood asking to get cut open its whole life its a 20R out of an 75 2wheel drive with less the 7xxxx :idea: so im gonna go over it and make sure that  motor is all good so i can have a grate spare oh and did i say also i get the propane setup as well every thing you need - the tank for  500 buck  :hammer: :hammerhead: :think:s im stoked
Turning
Over after
Years
Of
Trail
Aabuse
adamsbro1
ok way off subject and im sorry but i saw a picture of that dash where you had the radio installed in the same slot as the old stock, looked like it was some sort of adapter kit?  where did you get this???  i have been looking for a way to install a new radio in my 82 and have had no luck other than building a custom dash panel????  any help would be GREATLY appreciated.
tanabuse
yeah you know im really sorry i bought the truck wit it  in it but from what i can tell the black plasitc around the deck looked like it was just modifyed frome something like another deck cage cover but thats it and the deck is in a bird cage  mounted to the dash so all i can say  is be creative with it i know its like inpossible but may be just go into a local stero installer and bring your deck in and find something that fits around it niceley and find a way to mount it  on there mine dont even look like that no more i f***** it all up and the outer black cover wont stay on any more it was being held on by some black tackey apoxy  like substace i dont know for sure  well i hope some of this helps you out  and i was just not ranting off  :hammerhead: into wonderland lol well tell me or show me  how it turns out  :beerwhack:
Turning
Over after
Years
Of
Trail
Aabuse
Yeagley
Quote from: tanabuse on January 21, 2010, 10:50:03 AM
had too. to do two inch drivetrain lift so my tranny and transfer are above frame rails only thing hanging down is one inch of transfer out put
You didnt have to...You could of cut the floor and made the tranny and t-case all the way above the bottom of the frame. Now you raised your center of gravity.
tanabuse
#43
yeah well i could do that. but i would loose my heater. up here its wet and cold most of the time it sucks. and i'm allready hiting my body when i flex out up front on the spot for your feet
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well i have full on bord air via york with 12.5 gallons of air tanks and i have a propain set up i will be installing this weekend
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well i was driving around and my truck kept wanting to drag me  into the oncoming   lane when ever i would hit the breaks so i started to check :pokinit: out to my discovery i found this on my passenger side i think the picture says everything
Turning
Over after
Years
Of
Trail
Aabuse
fade
how in the hell do you do that?  I've seen rotors warped so bad they dont sit flat, and grooved really bad. But never one cut in half like that.
86 mini truck 18" rays
09 highlander
70 suburban
tanabuse
well i dont know i brought it in to my local napa when i bought a replacement they said they had never seen a  rotor  like  that befor. well they only thing i can say that may have to to do with it  wheel spacers and i dident cut it at all it sheered away from the pad surface areaand the crack is all the way through the dam rotor
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
 :thumbs: :flamer: i just picked up a miller 140 auto set and a plasma cuter  for $600.00 man i got a deal   :yupyup: dam its time to start the fabing :pokinit:
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well   where did my front axel go  :laugh:
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well i dont know but i diden't cut it it sheered off like that i took that of my truck needsless to say im runnng vented rotors now
Quote from: fade on April 20, 2010, 12:03:11 PM
Turning
Over after
Years
Of
Trail
Aabuse
fade
so what happend to your truck? the axle looks gone along with the leafs? Hope it was not stolen and found like that. But then I hope it did not break off either. So whats up?
09 highlander
70 suburban
tanabuse
nothing my truck is flexed out and my tire is just under brush looks crazy   :ack:
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
#54
so i just got a line up on a 83 celica with a 22re for $180 is that a good deal
lol of corse  it is its a whole car  :idea: im so happy its a runner get this its ben siting since november of 99 so i drained all the gas put two gallons in her . tossed in a battery.  checked fluids and started it up well if not for a half dead battery lol had to hook up jumpers and it fired right up  :rofl2: it idled at 1xxx no problems  :hammerhead: i sat there in amazement  :clap: god these motors are grate im stoked i have a weber 32/36 and a 20R so ill be happy to get a 22 R now
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
heres me flexing on a car it has a whole jeep body cramed in it
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
well bad news the 22 r i was gonna throw in has no trustwashers in it so back to the 20 R
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
#57
well guys sorry for no up dates my computer has ben down but the dont mean i havent got any thing done  so well where i left off i was doing up my head gasket well thats doing fine and well i bought a home brew pane set up so i got that running on my 20 R and i just riped my front axel out and bilt a new one cuz it was time so over all specs its a 81 houseing wit bobbys 30 spline super set i just got and talked to bobby in person hes a real nice guy  high pinion wit 529.s girzz locker and a six stud knuckles set milled out for a keyway and grade 8 cap bolts. and all the other :pokinit:  all v6 breaks  diff cover plate, top gusset ,knuckle gussets, backing plate and  rock ring kit king pin kit  :beer: soo will c how she holds up im only running 33 swampers so it should be quite torqey  i also got my twin sticks installed
the high pinion i bought from :turtle: and i live about and hour and 15 min from gram so i just went has paid bobby s little visit to day it was a really nice day today
Turning
Over after
Years
Of
Trail
Aabuse
tanabuse
plz help v6 diff
Turning
Over after
Years
Of
Trail
Aabuse
wakkjobb
You got a solid spacer? Shim that puppy and run it.
>>Dan
