leaking from third member
Started by sparkys83yota, January 10, 2010, 07:13:32 AM
sparkys83yota
ok guys. I am a newbie and i did try using the search button. so here is my question. I haven't driven my crawler for a while. This morning i noticed a puddle of fluid below where my driveline meets my front third member. I got a haynes manual but am not exactly good at working on my own rig yet. Where would you guys start and what could this be<<<
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
86bobbedtoy
most likely that seal,
cheap fix and easy to.
drop the drive line,
take off the nut that holds the flange on
take off the flange
pull seal
put in new seal, make sure to install it evenly, use a socket to put it in
ninja turtle
check out page 232 of your haynes manual.
86bobbedtoy
oh and for gods sake change mamber to member
sparkys83yota
so i checked the differential parts on marlins website. I am guessing you mean the pinion seals? And when you say member to member you mean do both right??
-Jake-
yeah its a pinion seal.  Just do the one that is leaking he was talking about how your title says "mamber".  When you put in your new seal pack it with lithium grease so the spring stays on the seal.  I also coat the outside of mine with RTV to make sure it doesn't leak.
86bobbedtoy
Quote from: -Jake- on January 10, 2010, 08:00:32 AM
smart
bigarms23
chicorider
my rear third member had oil condensation before wheeling trip so i went to tighten the bolts and they were pretty loose. i added gear oil and it's been fine ever since.
chicorider
i guess i should change my seal also just to make sure. that guy had a good idea using a socket to align the seal. i had to figure that one out for myself when i changed the one my transfer case.
boneyard customs
Silicone......... Find you some fake boobies and throw them in there ! seal her right up.
yota4x4sc
Quote from: boneyard customs on December 29, 2010, 08:29:29 PM
:biggthumpup:
yoshaleng
get Marlins heavy duty pinion seals.....changed mine last yr and hasn't leaked yet. that rtv trick is great idea!
Scuba
Some chant and meditate, I shift into 4Low.
Rockin a 99 Single Cab Taco, Locked lifted and armored sittin on 35" MTR Kevlars.
