We need your help!
Started by bigtoyfreak, January 30, 2003, 01:31:47 PM
bigtoyfreak
Please help
The area in the survey is a very large area (several hundred square miles) about an hour north west of Calgary Alberta Canada....
it is a detailed survey but the area I need you to fill out is section 9 and add 4x4/jeep mark it yes and mark 4-5 times
what the bastards do is they set the survey up only refering to OHV which they later define as only QUADs thus closing the entire area to 4x4's.
..in order to get 4x4's back on the agenda we need major numbers...last year they closed several 1000 square miles of land the same way with only 400 responses...If I can get 500 pro 4x4 email responses it would guarantee 4x4's can continue to run these trail...
question 11 asks for first 3 letters of a postal code use T2P
http://www.praxis.ca/gw/gwsurvey.htm
If you want to fill out the rest be my guest.... "Randon Camping" is camping you do not have to pay for you can pull off the side of the road anywhere and camp ...lot of young people take advantage of this and go out and party causing lots of problems most do not have 4x4's or a quad etc....the tree huggers are using this as a reason to ban everyone and are trying to sneak in banning 4x4's
thanks in advance and I will return the favor anytime
Paul_Elbisser
#1
Filled some out. Random camping, added 4x4. Left most empty since I was not educated more ion the issue.
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
