Author Topic: 20r 22r hybrid help me out !!!!!  (Read 8604 times)
0 Members and 10 Guests are viewing this topic.
motormouth559
  • Male Posts: 917
  • Member since Oct '07
« on: Jan 03, 2010, 07:49:25 PM »
so ill start from the top of the intake     going under the intake       to the back of the watter pump
then going from the lower intake
to the fire wall uper hose    then lower hose goes to cab . from here it comes out of the cab to lower watter pump
IS this all correct ??? The truck over heats after a few mins .
« Last Edit: Jan 03, 2010, 09:43:28 PM by motormouth559 »
motormouth559 [OP]
  • Male Posts: 917
Re: 22r 20r hybrid watter jackets help me out
« Reply #1 on: Jan 03, 2010, 09:11:45 PM »
well ???
motormouth559 [OP]
  • Male Posts: 917
Re: 20r 22r hybrid help me out !!!!!
« Reply #2 on: Jan 04, 2010, 05:44:17 PM »
some one.. anyone
funrunner87
  • Member since Dec '09
« Reply #3 on: Jan 05, 2010, 08:09:02 AM »
check your thermostat.  there was a recall on this, MAKE SURE YOU HAVE THE RIGHT ONE!!
motormouth559 [OP]
  • Male Posts: 917
« Reply #4 on: Jan 05, 2010, 07:33:27 PM »
I pulled the thermostat .. My question still stands is this all correct..  ???
minicrawlin
  • Turtle Points: 36
  • Male Posts: 388
  • Member since Oct '09
  • BAM!!
« Reply #5 on: Jan 05, 2010, 07:47:58 PM »
did you put the 20r head on yourself or bought like it?
the rocks Rock in South D SON!
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
« Reply #6 on: Jan 05, 2010, 07:53:13 PM »
Which head gasket did you use? 20r or 22r?  On my setup i ended up blowing the headgasket because some of the coolant passages were covered by the gasket. I think i originally used a 22r gasket and had to switch to a 20r gasket.  Sorry i dont remember for sure which one ended up being right.  Are all of your hoses getting warm? Before it overheats start grabbing all your hoses and find out which ones are warm, this may help you narrow down the problem.  And I cannot remember how the hoses go just by looking at the pics, I would need to have my old rig right in front of me to check it out
97 4runner Limited
motormouth559 [OP]
  • Male Posts: 917
« Reply #7 on: Jan 05, 2010, 08:07:44 PM »
So i know the port on the top of the intake is for the watter choke(normally) were does it tie into? I just want to make sure its all flowing in the rite direction
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #8 on: Jan 07, 2010, 05:47:16 AM »
come out of the top of the intake into the choke then goes to the heater core,  I'll try and scan a pic from a chilton book for ya
motormouth559 [OP]
  • Male Posts: 917
« Reply #9 on: Jan 07, 2010, 09:28:42 PM »
Thank you ill be looking forward to that
motormouth559 [OP]
  • Male Posts: 917
« Reply #10 on: Jan 07, 2010, 09:35:17 PM »
Well i have a 32/36 weber on it with a electric choke .. can i just cap the upper intake   port off as well as the lower intake and just run the hose from the heater core to the back of the watter pump??? or will this cause temp issues in the intake ???
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
« Reply #11 on: Jan 07, 2010, 10:26:39 PM »
if i remember right i still routed the coolant through the intake.  I think it helps it run better on start up in cold weather.  I dont really see a reason why you couldnt skip the intake though. I dont think coolant has to flow through it.
97 4runner Limited
« Reply #12 on: Jan 08, 2010, 10:58:19 AM »
unless you ever go into a hi altitude in the winter then your screwed
YotaJosh
  • Male Posts: 499
  • Member since Dec '06
« Reply #13 on: Jan 08, 2010, 12:33:13 PM »
Your pictures look correct. Here's a pic of my mostly stock setup.
As for your overheating issue, what condition is the radiator in? Are the internal passages plugged up? New or used water pump?
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
motormouth559 [OP]
  • Male Posts: 917
« Reply #14 on: Jan 08, 2010, 06:42:33 PM »
Radiator is used but in good condition, its from another truck i had, Water pump i assume is good it dont leak or nothin but ill prob pull it just to check it all out, Do you got a pic of the lower intake Yotajosh ??? maybe a good pic of were your heater core hose connects to your block and were your water choke goes ...
YotaJosh
  • Male Posts: 499
« Reply #15 on: Jan 09, 2010, 05:01:30 AM »
My setup is (well, was) exactly like your pictures and description describe, so you've got it right.
A good overall engine picture of your setup might help.
The water choke on my setup hooked to the intake right near where the throttle linkage is, exactly like your first picture, and then it went straight to the carb, and then out the pass side of the carb, to under the intake (forward hose), and then to the back of the water pump via the metal tube.
I'd get you more pictures, but my truck isn't put together yet from some work I'm doing.  :hammerhead:
motormouth559 [OP]
  • Male Posts: 917
« Reply #16 on: Jan 16, 2010, 11:25:32 PM »
So i solved the problem today i pulled off the intake tore it all down all new gaskets and what not it runs better than new :) no temp problem any more.
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
« Reply #17 on: Jan 16, 2010, 11:31:15 PM »
hmmm  must have been a gasket blocking a coolant passage or somethin
97 4runner Limited
motormouth559 [OP]
  • Male Posts: 917
« Reply #18 on: Jan 19, 2010, 08:50:49 PM »
I think so it was a cheapo feltpro gasket.
Last post Sep 05, 2004, 02:29:03 PM
by Marlin
20/22r hybrid
Last post Mar 15, 2015, 08:33:07 PM
by zippo
Last post May 15, 2005, 02:20:49 PM
by kneedownnate
Last post Mar 15, 2015, 01:17:41 PM
by SloCrawler
Last post Apr 08, 2011, 03:57:23 PM
by yotaneck13
