Author Topic: help with transmission  (Read 1339 times)
86toyota
  • Turtle Points: 2
  • Male Posts: 353
  • Member since Nov '07
    • Montana 4x4 Association
« on: Dec 28, 2009, 04:58:11 PM »
Well i took my truck to the shop today and found out it wasnt just a slave cylinder. something is making alot of noise somewhere near the clutch. so my guess is either a throwout bearing of a bearing in the trany. so im gonna try to drop that tomorrow and figure out what the hell is going on. since its 86 22r the tranny thats in it is a G52 or54 not sure which. There is a guy selling a 5speed t-case & tranny out of a 95 4runner so it should be G58 tranny and chain driven t case. Would that trany bolt up to my bell housing or would the 4runner bell housing bolt up to my 22r block? also would my centerforceII clutch and flywheel work with the 95 tranny. And last question....would my gear driven t-case bolt up to the G58 tranny? Any info you guys can give me is greatly appreciated!
T86OTA
86toyota [OP]
  • Turtle Points: 2
  • Male Posts: 353
Re: help with transmission
« Reply #1 on: Dec 28, 2009, 05:04:56 PM »
i called the guy and he said they bolted up to his 22re. so my bellhousing should bolt up to the trany and visa versa correct?
T86OTA
86toyota [OP]
  • Turtle Points: 2
  • Male Posts: 353
« Reply #2 on: Dec 28, 2009, 05:10:24 PM »
oh yeah and also would the stock 86 t-case x-member on my pickup work with the G58?
T86OTA
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #3 on: Dec 28, 2009, 05:13:51 PM »
I dont  see why uit wouldnt work
[img]http://bo
86toyota [OP]
  • Turtle Points: 2
  • Male Posts: 353
« Reply #4 on: Dec 28, 2009, 05:16:38 PM »
me either. i guess im just double checking because i dont know the differences between th G52/54 tranny vs. G58 or the difference between the RF1A t-case vs the VF1A t-case other than the VF1A is chain driven.
T86OTA
85_4RNR
  • Male Posts: 265
  • Member since Nov '09
« Reply #5 on: Dec 28, 2009, 05:27:23 PM »
a 95 4runner would have a r150f tranny if it was a v6. if a 22re, it would be g58
I work a 2000 BMW 540i 6 speed
85_4RNR
  • Male Posts: 265
« Reply #6 on: Dec 28, 2009, 05:29:26 PM »
just get new throw out bearing if the rest of tranny is good.
86toyota [OP]
  • Turtle Points: 2
  • Male Posts: 353
« Reply #7 on: Dec 28, 2009, 05:32:31 PM »
yes that tranny out of the 4runner is a g58. it come off a 22re. and my plan is to figure out what im gonna do after i drop the tranny and check the throwout bearing. im still wondering the difference between the g58 and g52/54. From what ive read the g series have 8 bolts on the bell housing. is one weeker than the other? :dunno:
T86OTA
86toyota [OP]
  • Turtle Points: 2
  • Male Posts: 353
« Reply #8 on: Dec 29, 2009, 05:43:03 PM »
pulled the tranny today. found out the throw out bearin was fine but it was wiggling around on the shaft because the clips that hold it on the shaft and clutch fork bent and fell off. so i gotta wait til thursday to get that in. in the mean time i pulled my tranny cases apart because my intermediat plate has been leaky for some time so im gonna reseal her up. hope to have her runnin again by friday
T86OTA
Last post Jan 30, 2003, 05:03:55 AM
by David
Last post Jan 26, 2003, 06:07:39 AM
by David
Last post May 02, 2005, 04:33:22 PM
by morerunner
Last post Apr 21, 2006, 08:36:00 PM
by jimbo74
Last post Nov 09, 2007, 08:02:48 PM
by kneedownnate
