Early and late model blocks are NOT the same. Toyota used a "tall deck" block until 1984, and then switched to the newer "short deck" design. there is a difference in block height of about 0.4 inches, and the heads are different. You can use that head on your tall deck, though(I think Marlin runs this setup). If I remember correctly, you need later model flat top pistons, but i could be wrong about that.
