Author Topic: 22r rebuild, Q about wrist pin....  (Read 6126 times)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« on: Dec 15, 2009, 12:14:06 AM »
im in the process of doing a rebuild on my 22r, down to the nitty gritty i am......  Anyone ever do there own wrist/piston pins.... i understand most people take em to the machine shop, but those that do it themselves how did you make em fit and how tight did you get em
Those are some huge welds!
Tillamook, OR
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 22r rebuild, Q about wrist pin....
« Reply #1 on: Dec 15, 2009, 12:28:18 AM »
Should be floating pins, was easy to do with a 20r I rebuilt.
From the FSM
"At 80 C (176 F), you should be able to push the pin into the piston with your thumb
If the pin can be installed at a lower temperature, replace it and the piston"
With the 20r, I think I just tapped it in........ (didn't feel lose, and with circlips I didn't worry about it)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Dec 15, 2009, 04:55:02 AM »
the pins should be snug,  but if they fall out if the clips arent in then theyre WAY too loose
the brass bushings (in the small end of the rod itself) should be installed and machined to fit by a machine shop
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #3 on: Dec 15, 2009, 12:52:12 PM »
ok i didnt go into the detail i should have, i got the bushings in the rods and the pins will not go in them without a high amount of force (ie plastic hammer) so i know they need to be machined or whatever.... i was just wondering if anyone had ever done them thereselves with like a brake cylinder hone or something...pistion pin to piston fit is fine....
Tillamook, OR
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #4 on: Dec 15, 2009, 03:09:42 PM »
Need a reamer.   A brake hone isn't presise enough.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
« Reply #5 on: Dec 15, 2009, 05:47:03 PM »
in theory you could use a brake hone, but you better keep your hone perfectly aligned,  USE PLENTY OF WD40
this really isnt where you want to skimp, but i understand sometimes youve gotta DO what ya gotta do
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #6 on: Dec 15, 2009, 08:53:28 PM »
my biggest problem around here is that i either dont trust the machinist, or my other option is 50+ miles away lol....  i will c what i can do.....prob just end up takn it to distant machinist
Tillamook, OR
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Dec 15, 2009, 09:24:47 PM »
The FSM says to hone the bushing.....  (not ream, sorry I'd alway heard ream)
But I wouldn't trust a brake hone.
See if you can find one specifically for piston pins.
Pin should fit with thumb pressure when oiled at room temp.
Clearance is .0002-.0004"
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #8 on: Dec 15, 2009, 09:48:49 PM »
If you know of someone you can trust, you could just ship the rods and pins to them........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #9 on: Dec 16, 2009, 12:37:08 PM »
well i got em in there, i will post pics up of the whole setup when i get a chance.... ends up the pins seem to fit into the rod just a little bit tighter than the piston, no wobble up down or otherwise.... i did take a run-out type gauge and try to measure any play that it might have and i couldnt get them to move soooo.... i guess worse thing that could happen i could toast my pistons/rods and have to take er back apart again... not to worried bout it now
Tillamook, OR
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
« Reply #10 on: Dec 16, 2009, 01:02:56 PM »
Heat the piston/Rod in the over to 176F and freeze the pin! If you read to FSM a little heat is ok. If it wont go with the heat. you need to move on the honing. If the Rod bushing need to be done, TAKE IT TO A SHOP WITH THE PIN. and save yourself alot of work. It goes on a stationary hone used on rods.
« Last Edit: Dec 16, 2009, 01:16:34 PM by zippo »
If you see it, its for sale.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #11 on: Dec 16, 2009, 03:23:53 PM »
The pins should be looser in the rod than the piston as there is some clearance (.0002-.0004") speced...............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
bleakhorizon [OP]
  • Turtle Points: 50
  • Male Posts: 803
« Reply #12 on: Dec 16, 2009, 07:10:43 PM »
yea uh how xactly do you measure that clearance.... lol. . . i havent put em all together yet so i can still mod them if needed
Tillamook, OR
« Reply #13 on: Dec 17, 2009, 09:37:30 AM »
if you had to push fairly hard with the thumbs your fine
zippo
  • Male Posts: 1,556
    • oppiz.net
« Reply #14 on: Dec 17, 2009, 01:11:11 PM »
Try switching the pins between them? Maybe you'lle get lucky
Last post Mar 14, 2004, 10:42:50 PM
by 84runner
Last post Jul 06, 2006, 03:27:03 AM
by johnboy
Last post Jan 09, 2007, 08:40:22 AM
by Tallchevy
Last post Dec 13, 2007, 04:08:02 PM
by 84pickup
Last post Jul 27, 2008, 10:59:44 AM
by sam2145871
