1981 toyota crawler (updated info)
Started by Tyler+Ashleys4runner, November 29, 2009, 12:11:16 PM
Selling my toyota pickup set up for crawling/ but still drives you to the trail and snow
just got done rebuilding building most of it, now I want a new project but a 4runner this time
$4000
gears
truck wil come with the 5.29s front and rear, soft locker up front and open in the rear.
front axle
84 front axle w
trail gear armor diff cover
trail gear top gusset
trail gear knucle service just done with bearings
hy-steer with steering box
u-bolt flip
different springs it's lifted 3" and also has a 3" body lift
1.5 wheel spacers
rear axle
89 Toyota 4x4 bigger brakes and 3" wider
the axle was shaved and plates to be stronger
different stock hoop put in to put the shocks in a v, and let there be more up travel
just put new brakes on the back
drivetrain
22r motor was rebuilt in the last 50,000 miles, has a rv cam ( motor leaks some oil from the front like timing cover or something just haven't had time to fix it just didn't seal good when I put it back together, i have a full gasket set for the engine
1983 Toyota L52 transmission bigger bearings in it then the 81, replaced the main bearings. But transmission still makes noise in the fifth gear normal problem I've found out about those transmissions, needs fifth gear bearing replaced if you don't like the noise.
daul transfer cases stock gears in both cases, custom made drive lines,
Stereo speakers 4" and 6x9" in the doors and 8" subwoofer behind the seat (old but still work)
cb with pa system, to rock light one on front diff and one on the rear diff and two light on the light bar
roll bar converted into a air tank was used for on board air, has a viair compressor under the hood with a pressure switch the turns it on at 85psi, and off at 105psi, also has a no/ switch
procomp m/tr tired 65-80% left full size spare different brand
Custom front whinch bumper (will include winch for 200 smittybuilt 8000lbs,) custom rear bumper and rock sliders
comes with full and half doors, trucks body isn't in the best shape but still looks ok
has buckets seats out of a newer toyota
Call or text for and questions 530-363-5599,
or email [email protected]
here are some pics
http://s928.photobucket.com/albums/ad124/toyotacrawler/
if you want pics just ask
1981 pickup  home build dual case 35" tires "sold"
1986 4runner diamond axle, tg axle 37mtr elockers f/r dual case "sold"
1990 sr5 4runner sas  35 km2's e-lockers front and rear. "Sold"
1995 4runner vw1.9 diesel, diamond axle
#1
adding new info and price
whatsayota?
bump for a nice little truck come on guys make the man an offer
84 xtra cab, dauls W/4.7, 5.29s, detroit rear/arb front, caged, longs, recentered H1s and 37s, my DD
