I just finished putting back together my motor after a new crank and bearings, got here timed right and running smooth. But It seems to me that the valves are a bit noisy. it is a brand new head, cam rockers, the works, and I currently have them ajusted at .08 intake and .012 exaust, but I can hear very slight (almost unnoticable tapping.) are these my only options without burning a valve or messing things up? and would it make a difference if when I put the motor at TDC it was on the 5 degree mark and not the 0 degree mark?
It's possible to put the rocker arm shafts in wrong with the result of no oil flow where there's supposed to be oil flow.................
I was once told by a toyota tech some noise is better then no noise
It's a mechanical cam, some noise is normal. I always thought they were too noisy setting them to spec and set mine @ .007 and .011. with a cold engine.
can incorrectly adjusted valves cause power loss?
would to tight cause power loss or to loose?
Started by Makohon « 1 2 » Engine
Started by partyman66 Engine
Started by acerbis Toyota Pickup/4Runner Tech 1979-95
Started by jeff94runner Toyota Pickup/4Runner Tech 1979-95
Started by Cletis Crawdad Engine
