Author Topic: Rod knock  (Read 1911 times)
ftoy07
  • Male Posts: 136
  • Member since Sep '05
Rod knock
« on: Nov 25, 2009, 04:43:56 PM »
hey everyone i have a 22RE motor that has a really mean rod knock. this thing is going to blow any second. does anyone know where i could get the parts that i would need to fix problem for a good price. also should i rebuild all the pistons and rods or just the problem one
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Rod knock
« Reply #1 on: Nov 25, 2009, 05:46:06 PM »
you'll need a full rebuild
stop driving it now, cause if it blows you will need to find a new block,  as of now it COULD be rebuilt
ftoy07 [OP]
  • Male Posts: 136
Re: Rod knock
« Reply #2 on: Nov 25, 2009, 06:31:53 PM »
it's in my formula toyota so as of now it just sits. where can i get a full rebuild kit?
Re: Rod knock
« Reply #3 on: Nov 25, 2009, 07:55:13 PM »
enginbldr has good  low cost parts but i use my local NAPA
Re: Rod knock
« Reply #4 on: Nov 25, 2009, 08:02:39 PM »
LCengineering has rebuilt "stock engines"
Re: Rod knock
« Reply #5 on: Nov 25, 2009, 08:04:22 PM »
http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=9C2ABD0B-C823-4AF1-B015-5F333F8680A3
ATK Remanufactured Engines offer expert craftsmanship, premium parts and machining. Engine block cylinder walls are bored and power honed, cylinder head mating surface and block mating surfaces are machined, engine block is line honed, crankshaft is magnafluxed, turned and polished, connecting rods are resized and balanced in sets, camshaft is re-machined, rocker arms are re-machined, valve guides and valve seat areas are re-machined.
ATK offers a 3-Year Unlimited Mileage Nationwide Warranty, FREE Delivery to the continental United States and FREE Shipping on Core Returns.
ATK Remanufactured Engines Include All New...
    * Pistons, Rings, and Valves
    * Main Bearings
    * Rod Bearings
    * Cam Bearings
    * Valve Lifters
    * Rockers, Nuts, and Swivels
    * Timing Chains
    * Cam Sprocket and Crank Gear
    * Oil Pump
    * All Gaskets and Seals Required for Installation
ftoy07 [OP]
  • Male Posts: 136
Re: Rod knock
« Reply #6 on: Dec 13, 2009, 10:41:04 PM »
Ok so i tore it all apart and this it what i found. the air intake was caked with sludge, come to find out this motor spent the night upside down haha. there was about two cups full of sludge built up in the air intake housing!!! the pistons had sucked some of the sludge in and crystallized it on top of all the pistons, the valves have a lot of build up on them to. is it possible that the hardened sludge was built up enough on one of the pistons that it was hitting the head every stroke and making a knock. i did find that the timing chain guides had a little bit of play back and fourth, could the chain be hitting them at all and making a knocking noise? other wise everything looks like it should   :dunno:    thanks for all the help guys
Last post Jul 27, 2007, 03:19:22 PM
by AaronB
Last post Feb 14, 2008, 03:47:46 PM
by Glen1978
Last post Apr 29, 2008, 09:28:24 PM
by JohnHalladay
Last post Dec 20, 2009, 11:06:05 PM
by mr.charli3
Last post Oct 21, 2010, 12:04:39 PM
by 79coyotefrg
