Alignment
Started by Fireimp141, November 13, 2004, 03:53:11 PM
Fireimp141
I just went down and bought new pitman and idler arms... i also need 2 tie rod ends, which im also asking where i could get some good tire rod ends for an 86 runner stock steering. And then, once i get all 4 of these things on, how do i got about doing the alignment. I know you measure the rear tires from somewhere to somewhere and turn the tie rod ends until the tires are the same front and back? am i correct on this? any help is appriciated
Thanx
Jareth
89 toy
count the threads on the ones on the truck and then when you put the new ones on put them the same. that will get you close and take it to the alinment shop
can you make it here??  i can fix you up if you can
counting the threads doesnt always work, sometimes you'll get a aftermarket  thats not the same but "works"
just measure the back of the front tires,  then the front of the front tires,  ok,  like at 3oclock and 9oclock,
Fireimp141
I still need to know where to get some tie rod ends, autozone and o'rielly's cost like $45 and $65 a piece, i want some good ones for that money!  :twocents:
Oriellys  carrys 'Moog'  steering components,  never had a problem with those
Fireimp141
AHHH they are expensive though for stock replacers :( o well might have to do that
just make sure whatever you get is greasable
Duffil
usually, for the money, NAPA steering components are about the best you can get.  All of our NCP line is Dana stuff...
