Author Topic: On board air compressors  (Read 16365 times)
big ron
  • Turtle Points: -5
  • Member since Aug '06
Re: On board air compressors
« Reply #60 on: Dec 10, 2009, 08:10:55 AM »
 :thumbs: fills up a 37x12.50x15 from 0psi to 35 psi in 9 minutes. thats before the porting mod. I have 2 that I'm going to use for my OBA. http://www.4x4wire.com/tech/portable_oba/
yota_krawler
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #61 on: Dec 10, 2009, 09:00:29 AM »
why not just use an ac pump or york pumo. plumb it and wire it up. then air up the tire?
100 bux at most, if you already have the pump
big ron
  • Turtle Points: -5
« Reply #62 on: Dec 11, 2009, 08:22:04 PM »
some people like having their AC :greengrin:
crawlerdad [OP]
  • Male Posts: 395
  • Member since May '09
    • Please ban me!
          OK!
      I am banned!
« Reply #63 on: Dec 11, 2009, 10:00:06 PM »
 :thumbs:  Big Ron that is what I was looking for when I started this thread. There is no way I was going to give up my AC living in So. Cal. I built a bumper that I plan to use as an air tank. So this should work great for me. Did you say you plan to use two?  :beer:
Precision guess work done here.
Dan The Man
  • Male Posts: 23
  • Member since Dec '09
« Reply #64 on: Dec 28, 2009, 01:06:14 PM »
Quote from: Volcom
Quote from: PhantomD aka Zach
it's a modified starter motor, not a winch motor. I have a friend that tried to make his own with a winch motor, it pulled WAY too many amps.
How did it work minus the pulling too many amps?  I'm really interested in making one.
x2. I'd like to hook my york up to something besides my engine. I saw a warn winch motor on eBay for $80 and was wondering if that would work.  :dunno:
'91 Wrangler - 5.7L, 4L60E, NP241, HP D44, Ford 8.8, 4.88's, 36" TSL's
'02 Chevy Ex-Cab
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #65 on: Dec 28, 2009, 01:53:05 PM »
Just a guess but I would bet it wouldn't be as fast because the winch motor has a lower RPM.  :dunno:
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #66 on: Dec 28, 2009, 04:45:53 PM »
You do realize that they are geared to be like 250 to 1 right? so without the gears its prob gonna be fast
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #67 on: Dec 28, 2009, 09:12:11 PM »
Learn something new everyday. I didn't know that.
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #68 on: Dec 28, 2009, 09:17:22 PM »
Max RPM on a York is 6K.  Most of those winch motors turn at 2K.  If I build one, I was thinking about gearing it to get closer to 6K for more CFM.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Dan The Man
  • Male Posts: 23
« Reply #69 on: Dec 29, 2009, 09:07:02 AM »
Quote from:  Volcom
You're right. A quick check on fleeBay and they typically all turn at 2100 rpm. Another quick search and I see the York cranks out 7.3 CFM at 2000 rpm, but I think that was at 0psi. At any rate, thats good enough for me to save time and hook that sucker directly up to the output shaft on the winch motor rather than dealing with the gearing. Only thing is I wonder if the 4.5HP winch motor would be ok turning the compressor when directly hooked up.
Any idea how many amps a winch motor pulls?
'02 Chevy Ex-Cab
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #70 on: Dec 29, 2009, 11:33:21 AM »
Here's the specs on a Warn M8000
http://www.warn.com/truck/winches/src/M8000.shtml
Line Pull Lbs.(Kgs.)    Line Speed FT./min    Motor Current
0                            42                          80 amps
2000                        16                         200 amps
4000                       11.9                         285 amps
6000                       9.79                         350 amps
8000                        8.01                        435 amps
So a fully loaded 8000lb Warn winch will draw 435amps.  I don't see a York putting too much strain on that 4.5hp motor so it can't be but 80-200amps.  Yeah, it will suck down your battery pretty quick but since it puts out a crapton of air, it won't take long to air up your tires.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« Reply #71 on: Dec 29, 2009, 12:47:00 PM »
I am said friend!
I used cheap winch motor (ramsey that would spin 7k RPM) and the york
Designed a really nice bracket in solid works, I built the bracket at work on the mill, looked pro!  Got the coupler from MMC to run it direct drive, bolted it all together and it ran like a sowing machine! Except that the jumper cables I was using to power it were glowing red hot......  I can't remember how many amps it drew, but it was a metric :pokinit: ton.  I don't think that the thing would even spin at 90 PSI.
Bottom line is, the motor I used (and I suspect many winch motors) depend on the gearing of the winch to make the torque.
Here is what I will do.  I will scrap it back together and make a new thread JUST about my compressor build.  I have more ideas about how to do this, but haven't had time to lay them out.  Also, I lost ALL of my drawings for the damn thing when I sold my old laptop. Dumbass here didn't remember to save to the new comp!  :hammerhead:
PZ
PS
PhantomD is on his way to my house, and we will get it fired up for some pics.
Dan The Man
  • Male Posts: 23
« Reply #72 on: Dec 29, 2009, 01:20:54 PM »
Phazertwo, I'm glad we found you. Now we can get info straight from the horses mouth. Depending on the size of your jumper cables, that may have been a limiting factor in getting power to your motor.
Volcom - I didn't realize winches drew that many amps. Considering your standard alternator puts out 105-145 amps you can kill your battery pretty quick if you aren't careful. Sounds like you have to gear down from the motor to the compressor which will cause your motor to pull less amps, but in turn lower your rpm of your compressor resulting in less CFM.
Phazertwo, let us know what your revised design entails.    :eyebrow:
'02 Chevy Ex-Cab
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
« Reply #73 on: Dec 29, 2009, 01:31:13 PM »
You are correct that the size AND LENGTH make a big difference.  We tried two different length of the same cable, (I think it was a 5-7ft difference) and the difference in the amp draw was quite surprising!
I am heating the garage now.  Should have some info for you soon.
I had no idea that this many people would be into this!
PZ
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #74 on: Dec 29, 2009, 01:38:03 PM »
Nice, I'd really like to build one as well.  I need something that I can air up 39.5" Iroks in a decent amount of time.  Thanks for posting up Phazertwo, it's nice to have some real world input on this project rather than just reading threads on the Internet.  That's a slick coupler.  Guess it's time to figure out some gear reduction for the motor to help out with the amperage pull.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Dan The Man
  • Male Posts: 23
« Reply #75 on: Dec 29, 2009, 02:33:10 PM »
Ran across these pics. This is pretty much what I'm trying to do.
Also, Thanks Volcom for the R&D. Let us know what you come up with.
'02 Chevy Ex-Cab
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
« Reply #76 on: Dec 29, 2009, 07:45:15 PM »
What can you tell me about this set up.
PZ
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Rollin on 37's
« Reply #77 on: Dec 29, 2009, 07:49:16 PM »
on a 4.3 L
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #79 on: Dec 29, 2009, 09:29:19 PM »
Before everyone disappears I want to thank you for the education. I learned a lot more then I expected to. :thumbs:
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
« Reply #80 on: Dec 29, 2009, 09:34:59 PM »
Oh, I think we are just getting started.......
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #81 on: Dec 29, 2009, 10:08:34 PM »
Even better!!
BlueRidge2016
  • Male Posts: 10
  • Member since Feb '09
« Reply #82 on: Dec 31, 2009, 03:26:22 PM »
 :therethere:
1980 Toyota Hilux, 5.0L 302 V8, Mod in progress: Dana 60 Rear Axle w/ 4:88 & ARB Locker's (It's no Rock Crawler, but it's a BLAST to :driving:)
Last post Aug 05, 2003, 01:25:06 PM
by BigMike
Last post Feb 05, 2009, 12:15:41 PM
by johnny916
Last post Jun 03, 2009, 06:24:59 PM
by kneedownnate
Last post Jul 07, 2010, 08:55:26 AM
by hilux-1983
Last post Mar 13, 2012, 12:11:46 AM
by Yotaman80
