To flip or not to flip?
Started by TacoRunner, November 06, 2009, 09:01:49 AM
Any problem with tapering a Marlin steering arms from the bottom?
No problem go for it.
Big problem, dont do it, buy new arms.
Do it but up grade to 1-Ton Chevy TRE for full contact = More Money
TacoRunner
So Im working on a project for a friend and I'm running into a problem and I'd like your take on it. (Dont worry about the project, its not important)
So that he doesn't have to buy custom steering arms from 4x4 labs, I want to mount his Tie Rod on the bottom side of his High Steer Arms. To do that I have to re-taper the arm. I'd like to re-taper the existing rod end holes, but from the bottom up.
Do you guys think this will be a problem with strength and reliablity?
Option #1 No problem go for it.
Option #2 Big problem, dont do it, buy new arms.
Option #3 Do it but up grade to 1-Ton Chevy TRE for full contact = More Money
www.4WHEELUNDERGROUND.com
[email protected]
88_Pathy
Why not put a hiem joint on the end and drill the high steer arm all the way through?
TacoRunner
Ball joints last longer then Heims, when used in steering. Thats what I've been told atleast.
[email protected]
-Jake-
is there any cone washers that might fit?  longshot i know...
46&2
I have been wondering this myself as I want to do the same thing. Have not spoken with anyone that has done it.
TacoRunner
Quote from: -Jake- on November 06, 2009, 12:05:29 PM
I like that idea, I dont think one exists but, they cant be that much to make. Cheaper then Chevy TRE's or new arms, thats for sure.
TP for you.
[email protected]
-Jake-
I think its possible know anyone that has a lathe?  I've made similar parts on a lathe for suspension parts on a formula sae car.
Volcom
Quote from: 88_Pathy on November 06, 2009, 10:56:34 AM
I did that modification this past year!  I like the heim joints compared to the TRE's.
As for tapering the bottom side of the hole, as long as the tapers don't run into each other, I'd say you'd be fine!
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
TacoRunner
Quote from: Volcom on November 06, 2009, 06:39:49 PM
Ya, that was the idea at least. Re-taper the same hole from the bottom side.
[email protected]
