Front Toyota Axle For Rear Steer?
Started by merlcrawl, November 03, 2009, 11:30:22 AM
merlcrawl
Ive always thought it would be awsome to have two front axles to create 4WS.
would this work or is the geometry going to be way off? im thinking of doing this setup on my 4runner if im not missing something here.. :help:
MC387
It would work fine.  Exept that the pumpkin is not centered.
-Jake-
or how about splice the balls onto a rearend housing (if theyre the same ID) and then do full hydraulic steering that'd be tits!
Cheesemaker
You would also need to narrow the frame!  :yesnod:
Or you could drop some serious coin and have Diamond axles made with Longfield custom axles.
merlcrawl
I dont see how the frame would need to be shortend, knuckle arms would probly be ideal for the inside of the axle instead of facing other open side for clearence reasons?
*** YELLER ***
except BACON
Slolyfe
Quote from: Cheesemaker on November 04, 2009, 07:34:11 PM
Do it!!! and post the build!
You'll never take me alive
-Jake-
Quote from: merlcrawl on November 04, 2009, 09:34:12 PM
He didn't mean shorten the frame he meant narrow it so when/if your flexing and turning your tires dont rub the frame
madmanweaver444
they did this for a buggy on powerblock extreme 4x4 you can watch it on spike.com
The mountains are calling and I must go.
-John Muir
merlcrawl
Quote from: -Jake- on November 04, 2009, 10:02:17 PM
ya i knew he ment that, i dont see why tho the front seems to clear just fine with a little body mod/cut
Quote from: ** YELLER ** on November 04, 2009, 09:40:25 PM
reverse cut gears :dunno:
nah thats not a problem think about it, the pinion gear spins the same direction theirfore you could rotate the axle 360 degrees.  i think what needs to be done is flip the steering arms on the knuckle to face the tcase instead of the back bumper.
OH are you tying to do this :DD
My Buddys 78
twistedtoy92
thats funny I was thinking about this last week.....
its actuated with an electric ram from a forklift.
he is noticing that its too slow obviously... I think he is going hydro rear now.
He daily drives it.
merlcrawl
thaats doope!!! did you guys flip the highsteer arms??? how do you hookup dual hydro stear???
its got the stock arms with the "J" cut off. and the stock tierod.
and I'm not sure. its got modified stock front steering and the stock arms in back with an electric ram.
Joey88RUNR
Quote from: madmanweaver444 on November 05, 2009, 02:38:31 PM
This is true, everything will need to be flipped 180, including the 3rd i beleive,  knuckels flipped, It was a good episode
*** YELLER ***
Quote from: THK90 on November 08, 2009, 11:51:12 AM
My Buddys 78
I do belive we all want to see this in its own thread and the details of the axle in motion and a detailed build or whatever he can remember of what he did
except BACON
they havent gone any further on that buggy in MONTHS! lol
Quote from: ** YELLER ** on November 09, 2009, 11:28:14 AM
I'll work on that this week. I'll see what pictures and information I can dig up.
1stgenboy
Is there not a way to tie the rear steer in with the front steer?
*** YELLER ***
Quote from: 1stgenboy on November 09, 2009, 04:02:01 PM
if there was that seems lika a bad idea since you usualy want to go a different direction with the rear than the front, at least from my experiance anyway,
except BACON
*** YELLER ***
maybe place a small toggle to run the rear steer on the steering wheel :dunno:
except BACON
grant526
Why would you want to?
The idea is to leave them seperate and control the rear with a valve.  That way it can go straight (like a normal rear axle) or you can turn it into or out of the turn, depending upon what you are trying to do.  I've wanted to build a rear steer/4wheel steering truck since I was a little kid.  It would be Awsome on the rocks!!
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
