Author Topic: 1984 pickup 22r  (Read 2093 times)
superkaliguy
  • Member since Oct '09
1984 pickup 22r
« on: Oct 24, 2009, 09:50:56 AM »
This is the case, I'm not to good with carburaters
but this is the scenerio, my cousin bought a 84 pickup but the car has been
sitting for 2 years. We tried starting it, but all it does is it cranks and No turn over.
But it won't start or turn over. I was told by some techs that the float boats have no gas since
It's been sitting for so long.    Anybody got any idea to start the vehicle. Any help and suggestion
is appreciated,  thank you
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
Re: 1984 pickup 22r
« Reply #1 on: Oct 24, 2009, 01:00:31 PM »
If you think its not getting fuel put just a small squirt directly into the carb, and give it a try, atleast then you will know for shure whether or not that is the issue. From there you can always put a rubber fuel line from the fuel pump into a container of gas, to check the fuel pump while eliminating the rest of the fuel system.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
superkaliguy [OP]
Re: 1984 pickup 22r
« Reply #2 on: Oct 24, 2009, 01:34:00 PM »
thank you. i'll give it a try
illinoisyotadriver
  • Member since Aug '09
Re: 1984 pickup 22r
« Reply #3 on: Oct 24, 2009, 03:46:41 PM »
x2 on sqiurting gas down carb if it runs then you know
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 1984 pickup 22r
« Reply #4 on: Oct 24, 2009, 05:46:46 PM »
sitting for two years the first thing i would do is pull the spark plugs and put a shot glass full of atf down in each cylinder and let it sit over night, then before putting the plugs back in spin the motor over to get the excess out , then put the plugs back in,  this will free up any rings that are stuck
X3 on pouring some gas (table spoon full at a time) down the carb
superkaliguy [OP]
Re: 1984 pickup 22r
« Reply #5 on: Oct 24, 2009, 08:59:52 PM »
i try putting gas in the carbs, whats weird is that now it seems its getting gas......but there is no spark. I put new coil and still no spark...is there any reason to that or is there anything elso i should look for why there is no spark...
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
Re: 1984 pickup 22r
« Reply #6 on: Oct 25, 2009, 07:28:17 AM »
you might get a test light and make sure the distributor is getting power when the key is switched on.  Check the rotor under the distributor cap make sure all the contacts are clean while youre in there.  Make sure your battery is good and charged too.  might see if the factory ground straps are still in place too.
superkaliguy [OP]
Re: 1984 pickup 22r
« Reply #7 on: Oct 25, 2009, 10:14:14 AM »
i'll check
Last post Jul 06, 2005, 01:19:28 PM
by ajkretchmer
Last post Jun 08, 2006, 10:03:25 AM
by ToysRus20
Last post Jun 04, 2006, 10:34:18 PM
by ftoy07
Last post Sep 10, 2008, 06:39:19 AM
by Addicted Offroad
Last post Oct 06, 2013, 08:19:08 PM
by Rocksurfer
