Author Topic: transfer case D.S. drop  (Read 2570 times)
Hilux808
  • Member since Dec '08
« on: Oct 22, 2009, 03:44:42 PM »
If I use the manual tranny that comes behind the 5vz on my 1990, wouldn't the drive shaft drop on the driver side? If so, Is there an an adapter that will make the transfer case drop my drive shaft to the passenger side?
DCabTaco
  • Turtle Points: 49
  • Member since May '06
Re: transfer case D.S. drop
« Reply #1 on: Oct 22, 2009, 04:09:42 PM »
http://www.marlincrawler.com/transfer-case/t/c-adapters/1995-2004-5vz-fe-34-liter-v6-drivetrains
then just put a regular gear driven t-case(which can be the one off your truck if it had one) from a pre-taco truck
04 SCed DCab Taco
85 4runner
97 Civic (DD)
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Oct 22, 2009, 05:27:48 PM »
are you using this in your 90 truck??  or a buggy of some sort??
your transmission should bea  R150  of which had a pass side drop factory but it was a chain driven case
if using a 3.4 liter v6 trans, then you can still put the pass side drop tcase on it i believe
Hilux808 [OP]
« Reply #3 on: Oct 23, 2009, 07:43:40 AM »
So this product will drop my drive shaft on the passenger side? Would I have to modify crossmember for the tranny to fit?
DCabTaco
  • Turtle Points: 49
« Reply #4 on: Oct 23, 2009, 09:09:24 AM »
We need more info.  What motor will you be using?  What transfer case do you have?
04 SCed DCab Taco
85 4runner
97 Civic (DD)
Hilux808 [OP]
« Reply #5 on: Oct 23, 2009, 05:29:05 PM »
I'm going to do a 5vz swap and using the manual tranny it comes with. Is marlins' adapter the only thing i need that will drop my drive shaft to the passenger side? :nonono: Will i need to modify my 1990 crossmember for the 5vz tranny to fit? :headscratch: What other problems might i run into when doing the swap? ???
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post May 22, 2009, 09:59:54 AM
by monk #1164
Last post Feb 25, 2010, 05:14:05 PM
by toy7521
Last post Mar 27, 2010, 09:00:12 PM
by TacoRunner
Last post Oct 27, 2010, 09:40:06 AM
by fade
