Marlin dual case hard to get into 2Hi
Started by yjay, October 20, 2009, 06:39:39 PM
yjay
I was out this weekend doing a lot of shifting from single reduction, dual case reduction, and also 2Hi. I found on numerous occasions that I had a tough time getting my rear case from 4Lo or 4Hi to 2Hi. It came out of gear easily but even if I bumped the rig forward or reverse it was hard sometimes. It's actually the first real trip it's been out since the build. Is it a common thing? Is there a technique or trick?
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
Joey88RUNR
sometimes you need to back up,  or get on some loose dirt,  if on hi traction surfaces  it can and will bind,  changing direction will alleviate this
freds40
Try pulling it out and putting it while slightly rolling.
"between projects"
yjay
I was on pretty level ground, tried moving forward and back a bit also and was always in loose dirt. May just take some getting used to and a bit more break in?
22re Daily Driver
axled89
mine the same way,  a little stiff some times. :cool:
i love oregon wheelin.
