same clutch old problem
Started by toyman2, November 05, 2004, 10:05:44 PM
toyman2
this happen to me last time
i pulled the tranny for a freshing up and when i put it back no clutch pedal and i never touched the clutch,master or slave cylender but last time it was all old so i just replced everything so it all farliy newerany ideas and yes it all worked fine before
im open for ideas i also have a run im trying to go on on sunday
Mike D
just bleed the slave cylinder then see what happens
toyman2
did it and nothing
nothing was ever open unless the seal sucke air from no pressure for 3 weeks
Mike D
maybe the cluch mastetr cylinder or the slave could be bad or maybe your lines could be clogged.  :headscratch:
toyman2
thanks but no way it is a closed hydrolic system and it all worked fine before
Mike D
What condition is the throw out bearing in.
toyman2
Did the fork fall off of the pivot ball?
toyman2
no its a preassure problem
im going to rebleed everything for some reason i think it got air in it from sitting
