Bump steer on an IFS
Started by AaronB, October 03, 2009, 12:44:08 PM
AaronB
I have had a lift on my 05' Tundra for about 4 years now and with in the last year or so it has been getting real bad bump steer. I stepped down from 35" tire to a 33" and that seems to be about the time it started. I put in stiffer bushings on the rack and pinion but it didn't seem to help. I'm not sure what else to do! Any suggestions would be appreciated.
and a SAS is not an option at this time.  :hammerhead:  :moon:
Snowtoy
Have you replaced the steering stabilizer?
Worn ball-joints and tie-rod ends can also cause bump steer.
AaronB
Quote from: Snowtoy on October 03, 2009, 04:46:19 PM
not sure what you mean? it has rack and pinion steering.
freeze365
It could be your caster.  Is your Tundra lifted?
G55 AMG | OHLINS | TE37 BEADLOCKS | MAXXIS
AaronB
Quote from: freeze365 on October 03, 2009, 05:55:49 PM
yeah it has 6" lift. I just had the alignment done yesterday, toed out a little on both sides, didnt fix the bump steer though.
Snowtoy
Quote from: Aaronb on October 03, 2009, 05:49:45 PM
You still have ball-joints(suspension) and inner/outer tie-rods(steering linkage) which when worn can still cause bump steer.  There bight be a way to install a steering stabilizer which would reduce the bump steer.
If you don't have it yet, here is downloadable Tundra FSM, that might help you.
