Author Topic: Wire questions! 94 Pick-up  (Read 1765 times)
binojames
  • Turtle Points: 3
  • Male Posts: 101
  • Member since Feb '07
« on: Sep 28, 2009, 04:23:10 PM »
so if you look at my build, You see i did a cab swap. I just hooked up the battery and everything seems to be working, lights,gauges, but... when i turn the key to "start" nothing happens. it doesn't make a click noise, as if i needed to bang on the starter. One other thing I don't have the gas tank in, would the gas tank connectors break a circuit and not let the truck start?
(just a test run i know it won't run if there isn't a gas tank in the truck, checking to see if the starter would pop)
« Last Edit: Sep 29, 2009, 07:04:24 PM by binojames »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Wire questions! 94 Pick-up
« Reply #1 on: Sep 28, 2009, 04:32:35 PM »
if its a carb no, the truck would turn over regardless,   efi??  i would probably think it could be your problem but i'm not sure
binojames [OP]
  • Turtle Points: 3
  • Male Posts: 101
« Reply #2 on: Sep 28, 2009, 04:48:58 PM »
yeah it is efi  well thanks  like i said it was just a test and i'm  not trippin
NorCalToy
  • Official Super Badass
  • Turtle Points: 77
  • Male Posts: 2,472
  • Member since Jun '07
  • IFS no longer! - Member #8342
« Reply #3 on: Sep 28, 2009, 07:59:42 PM »
i dont think it would. theres a plug under the pass side seat that runs the back half of truck (lights, fuel pump, etc) mine came unplugged so same as  no tank and the truck would still turn over and would start if i used starting fluid.
:flamer: IFS
mw85
  • Male Posts: 17
  • Member since Sep '09
« Reply #4 on: Sep 29, 2009, 08:15:48 AM »
do you have 12 volts to the starter? are the connector tight? if you put power to the key wire on the starter does it still click? maybe your starter just failed. i would check the connections first
nothing to be said
chim
  • Turtle Points: 1302
  • Male Posts: 1,258
  • Member since Apr '05
  • www.infowars.com
« Reply #5 on: Sep 29, 2009, 10:36:58 AM »
Could it be the clutch cancel switch possibly?
binojames [OP]
  • Turtle Points: 3
  • Male Posts: 101
« Reply #6 on: Sep 29, 2009, 07:03:49 PM »
Well i haven't tried putting 12 volts to the start, and i tried the clutch start cancel button and pressing in the clutch
Last post Feb 04, 2005, 05:17:38 PM
by Hyena
Last post Feb 23, 2006, 07:13:05 PM
by 79coyotefrg
Last post Feb 28, 2008, 09:46:40 PM
by yodersgirl
Last post Feb 13, 2011, 08:57:18 PM
by BoG-ToY
Last post Nov 25, 2015, 06:43:04 PM
by jimbo74
