Author Topic: old truck, new guy... lift questions with pics !  (Read 2979 times)
xyzalvarez
  • Member since Aug '09
« on: Aug 31, 2009, 08:24:39 PM »
howdy!
just got a new daily, a 85 pick up xtra cab, with a 7"  lift with 33" tires and  goodies a month ago.
and now im looking for upgrade it...as a any guy with a new toy.
I have a set of superlift springs in the front ( 7" lift )  part # 7007
and  stock springs with an add a leaf sitting on two blocks.
the truck sits straight...the front is equal to the rear.
after lookin for that " flexing " back there, a friend told me to remove the blocks before something can happen.
also the wooble is horrible on the streets..and not to mention fwy.
now heres the main question:
Im looking at the Marlin, trail gear , sky jacker or even procomp leaf springs.
but dont know wich one to get ? how high ? i even found some skyjackers 7" lift, ("  stock bolt on location ..." ) as rep said.
or should i get a set of 6" marlin's or even 5" trail gear spring set?
i "heard " that i need to get the fronts leafs a little higher  in order to compensate the engine load compared to the rears.
fronts 7" spring tend to get 6" because of the load, so the rear has to be 6" ? is that th right approach in my case?
because i have less than 11 posts cant post a pic, so heres the link.
help me to get rid of this..!
http://i165.photobucket.com/albums/u70/b16crx_2007/IMG_5345.jpg
thanks in advance
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
id get rid of the front springs and get 4 or 5inch marlin springs both front and rear
BAMF
  • Turtle Points: 40
  • Male Posts: 179
  • Member since Jun '08
I don't know much (refer to all my threads about things I don't know) but what I do know is that those blocks in the rear look scary.  The first thing I would do is get rid of those blocks.  Or at least get rid of the smaller one so you're not stacked double like that.  The second thing I would do is post some pictures of the front end and the steering set up.  If someone did something as shady as double stack lift blocks chances are there is more safety hazards all around.
As for springs, you really can't go wrong with Marlin.  They'll give you the lift you're looking for and later on down the road when you start worrying about flex you'll realize, "Hey, these Marlin springs flex great too.  Sweet.  Who's got some lockers for sale?"
I've got Marlin 4" up front and 5" out back.  I was more worried about the added weight of the 4Runner top sagging the rear of the truck, not the front.
Stay away from Trail Gear though.  That is just my  :twocents:
All tyranny needs to gain a foothold is for people of good conscience to remain silent.
xyzalvarez [OP]
thanks guys..!
i would really like to get the full kit, but cant right now  i need to focus on the rears only...
later on i can go to the fronts springs.
taliking about the front.
they're sitting on the axles and  the gear box  comes with a S shape tube and some adapters for the steering link.
i will take some pics of it.... probably is not the greatest hi-steer kit either.... need to adjust the nut to loose the woobling steering feel.
about the springs:
based on the lift i have in the front.  im on 33" tires , 3" in blocks and an extra leaf in the back...
what spring height should i look for the rears ? how much does the fronts usually  sags in order to look for the rears?
i just want to get even look...or an inch lower in the back..if i fail to get the right height..
what would you guys look for in order to nail it?
i was about to get some 6" skyjacker springs from my local shop...but somehow i didnt trust the sales rep.. lol
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
with 33's you definatly want 4" springs. it will ride better, take corners better and wheel better.
i would do 4" front and back, if the back ends up too low put that lower block back in and you can get some height out of that. and while your at it get a hi-steer kit, you wont regret it.
oh my 2 cents go with marlin or all pro.
UA 342
STEAMFITTERS
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Just so you know the rear Marlin, All Pro & TG springs don't bolt to the factory locations. You will have to cut & weld. The ride is better due to the longer spring. All the springs that are a direct bolt in will ride way too stiff & won't flex  :twocents:
http://www.marlincrawler.com/suspension/leaf-spring/leaf-spring-kit-rear
Install longer rear shackles. Stay away from blocks if you can.
87 4Runner redo
8485runner
  • Male Posts: 107
  • Member since Jun '09
I will agree!  Stay away from the blocks in the rear!  4in marlin or allpro will be well worth moving the hangers and shackles. Should clear 33's just fine
85 4runner, 36" Iroks, locked 5.29's, 30 spline Longs, MC 4.7:1 single case, bobbed 12"
96 4runner 2 1/2" daystar, 285/70/17 Pro Comp Xtreme Allterrains on black 17" FJ wheels
88 ext cab pickup bone stock, 1st gen tacoma wheels wrapped in 30x9.50x15 BFG Allterrains
xyzalvarez [OP]
ok ! i'll do it... i will relocate the hangers then..
the 4" lift with stock shackles will be enough then?  it will sit even or a little higher in the front..?
or 3" lift with 5" shackles as someone mentioned me before....?
82juguete
  • Turtle Points: 5
  • Member since Jan '07
I would go 4" marlins front and rear... the weight of the motor has some effect but not enough to go 5" in front.  If anything, i would consider removing a leaf or two and lowering the back (can be a little stiff).  I've seen 5" springs cause people to lose 4wd because of the extreme driveshaft angle up front, so if your not up to the task of cutting and turning your axle or doing dual cases, stick with the 4 inchers with either stock or 1" over stock shackles.  :thumbs:
xyzalvarez [OP]
thanks.
4" marlins with hangers relocated on stock shackles.
if the truck sits low, then upgrade with new shackles then.
Wish i can find a marlin dealer shop around so i can save on the shipping...but i'll be ordering this then.
hey btw 82juguete, i been reading your build thread...nice work there..!
82juguete
  • Turtle Points: 5
Thanks, and yea i have 4" marlins all around on my truck so if your looking for reference pics there ya go.  I think it sits nice with them.
xyzalvarez [OP]
OK dokey
Today tuesday im ready to order..
i have two companies which looking at their 4" rear kit.
im not a hardcore offroading guy, but who knows later.
so im wondering:
there's another dealers selling MC rear kits , besides MC ?
the reason : i found a couple of dealers of the other kits located in
other states wich they carry free shippping and tax exempt.
im not cheap but i want to get the best deal that i can get.
as a newbie im not biased by any company, and im eager to get my kit today.
both kit runs for the same amount. the only diff is shipping and tax..lol
where you guys go their MC kits besides here ?
thanks
Tallchevy
  • Male Posts: 3,562
87 4Runner redo
xyzalvarez [OP]
i just contacted most of them...
thanks
Last post Jan 11, 2007, 11:06:47 PM
by boggerunner
Last post Jul 27, 2007, 04:48:42 PM
by DTB
Last post Aug 26, 2007, 09:22:05 PM
by wombat
Last post Sep 19, 2007, 08:45:35 PM
by twistedtoy92
Last post Mar 25, 2012, 07:46:12 PM
by Rocksurfer
