Gears?!
Started by SWAMPER, October 28, 2004, 06:27:33 PM
SWAMPER
Im wondering what toys have what gears I may want to get lower than 4:10's so is there any toy out there (new or old) that has lower gearing that I could just swap 3rd members with?  Could I just do this with out any problems? and how much would you guys pay for each third? thanks a bunch :beerchug:
KYOTA
#1
Pasted from Pirate Toyota FAQ section
Differentials – Gearing
Gearing..... with a 4 banger and single case
stock 3.96 or 4.10= 31 or smaller tire
4.88=33 inch tire
5.29= 35 to 38 inch tire.
5.71= NOT RECOMMENDED FOR REAL OFFROAD USE
Originally posted by DSI
83-older 4.11 diff's are 37/9 and are 8in 4cyl style diff's, in 84 they switched th the 41/10 ratio, any time you have more teeth to a pinion the stronger the diff will be, reason being: more tooth contact/more teeth contacting the ring gear at one time.
This is the same reason 5.71's are very weak, 6 teeth, 5.29's have 7, 4.88's and 4.38's have 8, 4.56's have 9 and 411's have 9, 410's have 10, and 390's have 10
Originally posted by TNToy
If you have the axle code of your vehicle, it is easy to find out what size differential, what ratio, and what pinion set-up you have. This will also help if you are hunting for a particular unit off another vehicle. The axle code is in the vehicle ID plate under the hood or drivers door. The axle code is 4 digits: a letter followed by 3 numbers.
Example: F372 = 7.5" 3.58 final ratio 2 pinion
Code:
1ST DIGIT R&P SIZE 2nd/3rd Digit R&P RATIO 4th DIGIT PINION SET-UP
A    138mm    O1    3.30    2    2 pinion
B    145mm    O2    3.36    3    2 pinion LSD
C    6.25"    O3    3.55    4    4 pinion
D    6.62"    O4    3.56    5    4 pinion LSD
E    7.1"    O5    3.70
F    7.5"    O6    3.89
G    8.0"    O7    3.90
H    9.0"    O8    4.11
J    9.25"    O9    4.22
K    9.5"    10    4.38
L    10.5"    11    4.44
M    12.5"    12    4.63
N    13.5"    13    4.79
P    14"    14    4.88
R    162mm    15    5.13
S    6.38"    16    5.29
T    6.7"    17    5.60
U    6"    18    5.71
V    10.6"    19    5.83
W    15.5"    20    6.17
X    142mm    21    6.67
Y    158mm    22    6.78
          23    6.83
          24    7.64
          25    4.56
          26    5.57
          27    3.36
          28    4.30
          29    4.10
          30    3.73
          31    3.91
          32    6.59
          33    7.50
          34    6.78
          35    7.64
          36    4.78
          37    3.58
          38    3.42
SWAMPER
Thanks for the info KYOTA, but what I was asking basicly asking is what Toyotas have lower gearing than 4:10's on the thirds I want to change the third for one that has lower gearing like 4:56 or something like that....ok kinda same question...let say I find a 96 4Runner with the stock gearing being 4:56 I could be able to get the rear third and put it on my truck but what about the front?  Would I just take the front out how much of the front 7.5 axle do I need to take out? Thanks
LS :beerchug:
kyle_22r
'79 and '80 had 4.375 gears in all 4x4s
'81 had 3.90s :laugh:
from then on, the stock ratio for trucks at least was 4.11/4.10, autos got 4.30s, 31" tire package with a 5 speed had 4.56s, 31" tires with an auto got the oddball 4.88s
SWAMPER
Well I checked and I have 4:56's :bling: That is sweet I would like to go 4:88's though but I dont want to do a gear job i just want to slap on some thirds with it....hence the question as to what toy had them stock.
SWAMPER
Quote from: kyle_22r on October 28, 2004, 07:33:27 PM
Only the ones that dint have ABS had the 4:88's which actually are 4:875 the ones that have 4:56's are V6 with 2wheel ABS
