Author Topic: Frame paint  (Read 2241 times)
anarchy joe
  • Turtle Points: -2
  • Member since May '09
Frame paint
« on: Aug 13, 2009, 06:34:54 PM »
Fellas:
Saw some surface rust on the frame going to sand it out and repaint.What have you guys been using on your frames?
Thanks
anarchy joe :beer:
84solidaxletoy
  • Turtle Points: -3
  • Member since Aug '07
Re: Frame paint
« Reply #1 on: Aug 13, 2009, 06:39:45 PM »
krylon :) cuz its easy to touch up
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: Frame paint
« Reply #2 on: Aug 13, 2009, 06:42:42 PM »
Its more expensive then most paints but check out Por15.  It dries VERY hard and can take a beating.  Works great on axles and frames.
84pickup
  • Male Posts: 335
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
Re: Frame paint
« Reply #3 on: Aug 13, 2009, 07:24:16 PM »
i'd use POR 15 or some good ole rustolem. or you could get some cheap rattle can bed liner lol
lets not and say we did.
anarchy joe [OP]
  • Turtle Points: -2
Re: Frame paint
« Reply #4 on: Aug 13, 2009, 07:38:00 PM »
You guys using a primer or just spray n pray?
Anarchy Joe
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,072
Re: Frame paint
« Reply #5 on: Aug 13, 2009, 08:14:42 PM »
X2  on rustolem + primer
8D3TOY
  • Member since May '05
Re: Frame paint
« Reply #6 on: Aug 13, 2009, 10:37:08 PM »
POR15 has some great stuff I think its called chassis black or something like that, cheaper than the actual POR15 and not damadged by UV.  I used it on my dump trucks frames and 8 years later still looks great.
Grunt
  • Turtle Points: -1
  • Male Posts: 32
  • Member since Mar '09
  • Improvise,Adapt,Overcome
Re: Frame paint
« Reply #7 on: Aug 16, 2009, 03:19:33 AM »
Just did the frame on my 86 with rustolem rust converter. Looks killer. Kind of satin black, easy to use, cheap @ 5$ a can.  :disturbed:
With your shield or on it
TheGaJoker
  • Member since Aug '09
Re: Frame paint
« Reply #8 on: Aug 19, 2009, 07:00:49 PM »
check the eastwood company for lots of choices.
birfection
  • Turtle Points: -4
  • Male Posts: 203
  • Member since Oct '09
  • Drummond Island
Re: Frame paint
« Reply #9 on: Dec 01, 2009, 07:46:59 PM »
I came across a product at the auto parts store called Chassis Coat. It's quite a bit cheaper than Por 15 and it is basically the same product.
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
Re: Frame paint
« Reply #11 on: Dec 14, 2009, 02:48:00 PM »
My buddy uses Hammerite in a can. Very tough, brushes on with a paint brush or roller or gun if you thin it out. Not that expensive for what you get if you buy it in a can like that.
motormouth559
  • Male Posts: 917
  • Member since Oct '07
Re: Frame paint
« Reply #12 on: Dec 14, 2009, 09:16:55 PM »
primer+ good old rattle bed liner works good so far! :)
  • Turtle Points: 1128
  • Male Posts: 9,757
Re: Frame paint
« Reply #13 on: Dec 14, 2009, 11:47:19 PM »
POR15 or rust bullet.
wakkjobb
  • Turtle Points: -18
  • Male Posts: 1,590
  • Member since Dec '08
  • Back at it after 5 years!
Re: Frame paint
« Reply #14 on: Dec 15, 2009, 12:12:03 AM »
if all else fails, 3M undercoating.
IronClad: If I wanted to hold hands and be nice I'd become a hippie.
94MtnYote
  • Turtle Points: 6
  • - 94 std cab-
Re: Frame paint
« Reply #15 on: Dec 15, 2009, 01:55:42 AM »
yeah sprayed my front bumper with 3M Dynapro and it works.  that  :pokinit: is tough
 Marlin 1200LB clutch
gray
  • Male Posts: 23
  • Member since Nov '05
    • photobucket
Re: Frame paint
« Reply #16 on: Dec 15, 2009, 05:07:03 PM »
POR-15 good stuff!!
86 pick up 39's ,propane ,5:29's longs ,Detroit 's duel cases w/4:70 in rear case,twin stick,ceramic clutch ,rear disk brake convertion,cut and rotated front axle, inboard rear springs,exo cage,flat bed
CanTheWhales
  • Member since Oct '08
  • Stocker w/ a Locker
Re: Frame paint
« Reply #17 on: Dec 19, 2009, 11:57:58 AM »
I use that stuff alot...works awesome
Last post Dec 16, 2004, 08:11:34 PM
by yotaboy79
Last post Dec 16, 2006, 06:02:05 PM
by DTB
New paint job
Last post Jan 19, 2006, 02:35:09 PM
by kiyul4130
Last post Jan 12, 2007, 03:03:34 PM
by rlwjaw
Last post May 31, 2007, 05:34:12 PM
by jimbo74
