Author Topic: light cracking on t-case housing  (Read 1763 times)
micahturner
  • Turtle Points: -2
  • Male Posts: 51
  • Member since Jan '09
« on: Aug 10, 2009, 10:29:04 AM »
I noticed some light cracking on the front housing of my Toyota turbo t-case near the input shaft. The cracks do not go through and no leaking is evident. Is this common and should I look at replacing the front portion of the housing soon? Thanks.
Micah
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
Re: light cracking on t-case housing
« Reply #1 on: Aug 10, 2009, 02:23:53 PM »
Are you sure it's not just casting flash?
micahturner [OP]
  • Turtle Points: -2
  • Male Posts: 51
« Reply #2 on: Aug 10, 2009, 02:32:09 PM »
Not too familiar with that term
84solidaxletoy
  • Turtle Points: -3
  • Member since Aug '07
« Reply #3 on: Aug 10, 2009, 03:51:58 PM »
that was probably the coolest reply i have ever seen.
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #4 on: Aug 10, 2009, 04:37:24 PM »
Drill a hole at either end of the crack and weld it
micahturner [OP]
  • Turtle Points: -2
  • Male Posts: 51
« Reply #5 on: Aug 10, 2009, 07:13:02 PM »
It's not casting flash. They are very small cracks that are mainly around the input shaft. When ever I get back to Oklahoma I'll take a picture of it.
*ROKTOY*
  • Male Posts: 1,066
« Reply #6 on: Aug 11, 2009, 07:01:15 AM »
 :worthless:
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #7 on: Aug 11, 2009, 07:49:11 AM »
Does it look like this:
Or like this:
8D3TOY
  • Turtle Points: 5
  • Member since May '05
« Reply #8 on: Aug 11, 2009, 02:52:06 PM »
Both of those can be repaired by drilling a hole at the end and welding it.
I bet you are seeing casting flash looks kinda like a shattered glass pattern.
micahturner [OP]
  • Turtle Points: -2
  • Male Posts: 51
« Reply #9 on: Aug 11, 2009, 03:03:23 PM »
8D3TOY,
It does look similar to shattered glass.
Mini,
The cracking is around the input shaft area of the housing.
8D3TOY
  • Turtle Points: 5
« Reply #10 on: Aug 11, 2009, 09:36:53 PM »
I think you are OK my T-case is covered with it just keep an eye on it and see if more develops or if the existing gets worse.  When you can post up a pic and I am sure you will get a for sure answer as to what it is.
micahturner [OP]
  • Turtle Points: -2
  • Male Posts: 51
« Reply #11 on: Aug 12, 2009, 05:51:50 AM »
Thanks. I'll be pulling it out of storage on the 19th so I'll take pictures then.
Last post May 16, 2002, 01:30:37 PM
by BigMike
Last post Mar 28, 2007, 08:59:42 PM
by UKMyers
Last post May 24, 2007, 02:38:09 PM
by H8PVMNT
Last post Nov 02, 2007, 07:52:56 PM
by 89toy
Last post Aug 18, 2008, 06:56:23 PM
by BoG-ToY
