1994 4Runner 500$
Started by docked4runner, July 26, 2009, 12:25:19 AM
docked4runner
Truck has no motor but everything else is perfect, in one pic shows flat tire and missing tire, but the air is just let out and tire was taken off they are all perfect
TIMS89CRAWLER
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
BoG-ToY
appears to be in ca just south of LA
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
docked4runner
boggerunner
would u be willing tio sell the rear 3rd, pass side headlight setup and grille?
it should have 4.88's in the diffs
SocalWheeler71
Quote from: boggerunner on July 26, 2009, 09:57:18 PM
I doubt it. You can see in the pic the axle code is G072. The axle code for 4.88's is G144. It appears to be a 2wd, AFAIK only 4wd's came with 4.88's.
boggerunner
dam, i missed that part, so i guess just the left headlight and grille?
docked4runner
i just want it go go as a whole
