Jul 17, 2024, 02:20:22 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Engine
(Moderators:
OOPS
Cheesemaker
Topic:
Need Help
Pages: [
1
Go Down
Print
Author
Topic: Need Help (Read 1076 times)
toywthbdydmge
4WD Legend
Turtle Points: 240
Member since Mar '05
Need Help
on:
Jul 21, 2009, 09:57:12 AM »
OK I decided to move my wires around and eliminate some wires that were just hanging but in the process I broke a piece on top of the valve cover so I just plugged up the hoses. The problem is it starts and runs fine but under any kind of load it just dies on me but starts right back up so I'm wondering if the two circled items could cause this seeing that the hoses I plugged were connected to these. The motor is an 88efi Thanks
Logged
Rock Ninja
Gold Turtle Award
Turtle Points: 1452
Member since May '02
Solid axle Toys Rule ! ! !
Re: Need Help
Reply #1
on:
Jul 21, 2009, 01:12:30 PM »
i'm not sure what they do but its very possible its the problem
Logged
AR-TTORA founder
22R bored.060,
LCE stage II race cam
http://pure-gas.org/
32/36weber,
Marlin 1200 NON ceramic clutch, L52SHD+dualcase #2919, cable-locker, Yukon 5.29 gears, 35's, Allpro ebrake, front springs, and high steer, F150rears
RIP Nitro 9-29-07
I sure miss him
MarlinCrawlerInc
IS NOT
affiliated with TrailGear in any way
*ROKTOY*
The 1K Club
Turtle Points: 0
Member since Nov '06
Re: Need Help
Reply #2
on:
Jul 21, 2009, 01:58:16 PM »
I would hook up the rear VSV as it looks like it has to do with your fuel pressure regulator. The other has to work with the evaporated emissions charcoal canister.
Logged
emsvitil
Silver Turtle Award
Turtle Points: 7571
Member since May '07
Re: Need Help
Reply #3
on:
Jul 21, 2009, 02:04:26 PM »
The VSV on the left ups the fuel pressure in 4WD when your engine is to hot by venting vacuum to atmosphere...
I don't think it's really needed, and it's for such a small percentage of running conditions, you really don't need it.
For that one, connect the 2 hoses that go into it together, omitting the VSV.
(the hose will then apply vacuum to the the fuel pressure valve to vary pressure depending on intake vacuum).
I don't have the VSV on the right, but it looks like some sort of smog thingie.
I would think that plugged up the engine would run better (although with more smog), but you could try connecting the hoses together like the VSV on the left......
Logged
Ed
SoCal
86 SR5 XtraCab
22RE W56B
31x10.50R15
zippo
The 1.5K Club
Turtle Points: 550
Member since Nov '08
Re: Need Help
Reply #4
on:
Jul 23, 2009, 09:23:18 PM »
VSV vaules cause your engine idle to go up, when it is under load, IE, AC, power steering pump, Engine temp, and 4WD, etc. I removed most of mine and the EGR valve. really noticed a possitive difference too...
Logged
If you see it, its for sale.
Pages: [
1
Go Up
Print
Engine
(Moderators:
OOPS
Cheesemaker
Topic:
Need Help
