Ac question
Started by Thumper, July 17, 2009, 04:55:45 PM
Thumper
Ok need too know where the low pressure switch is on a 90 threw 95 toyota 4 runner, anyone got an idea found the highpressure i think its behind the grill but by compressor wont kick on becuase it has been low on gas for awhile and i think its stuck.
Thanks
adam
hilux-1983
exactly what year is it and is it a 4wd or 2wd and motor size?
Thumper
Its a 92 4runner 4wd with the 3.0 v6. Other specs are 4.5 superlift suspension 3 inch body 35s on mickythompson classic 2 wheels 5.29s detroit truetrack rear.
Ohh ya and its a 5 speed
Snowtoy
#3
Here is an exploded version on ToyoDIY.com, and the part number.  The A/C cooling unit is under the dash on the passenger side.  Here is a the FSM steps for Removing the Cooling Unit or  The complete '93 FSM.
hilux-1983
Quote from: Snowtoy on July 17, 2009, 09:36:00 PM
I wish that site had the whole manual for an 83 4wd. Nice job, by the way
Thumper
Wow thats a heck of a find! That helps me out alot sucks i gota tear the whole dash appart but owell least ill get my ac workin.
Thanks for all the help. :beerchug:
Now off too tear into the dash.
Broyota
You should check pink wire going to the cooling temp sensor. On the back of the in-take manifold there a cooling temp a/c cut off switch witch needs to see a ground signal to work.  This is a common problem with the 3.0l 4runner. You should check this before going into the dash, its easier.  Good luck.
