HELP NEW TIMING CHAIN AND GUIDE
Started by MidgetMike, October 21, 2004, 09:58:18 PM
MidgetMike
I'M CONVERTING MY EARLY 84 22R TO A DUEL CHAIN LIKE IT SHOULD BE BUT I THINK THE GUIDE BOLTS ARE WRONG, IT HAD A PLASTIC SINGLE ROW CHAIN GUIDE AND THE OIL PUMP DRIVE GEAR ON THE CRANK SHAT LOOKS TO LONG NOW I NEED THIS TOGETHER ON SATURDAY
lowgeared
Did you get the shorter oil pump drive spline?  That is the only difference.
lowgeared
splines pic
MidgetMike
#3
THANKS, I FIGURED I MISSED 1 OR 2 PARTS ARE YOU SURE THAT THE BOLLTS THAT HOLD THE GUIDES ON ARE THE SAME? :usa:
:gap: PROB SOLVED AUBURN TOYOTA WILL HAVE MY PARTS IN TOMORROW, I ORDERED KNEW GUIDE BOLTS BECAUSE THE DUAL CHAIN GUIDE BOLTS HAVE A DIFFERENT PART #
:hammer: :pokinit: THIS IS TAKING FOREVER!
or you could have just ordered a timing k for a 20R :usa:
MidgetMike
i could have but they dont come with t-guide bolts or a oil pump drive spline gear :beerchug:
lowgeared
Every kit I have bought (4 I think) plus the double roller set came with new bolts.  They all were the steel guide type if that made any difference.  I also had to find a spline seperately.  20.00 from Toyota.
just take your old chain gear and new chain gear and drive spline to a machine shop and have them shorten the drive spline shouldnt charge more than $10
as for bolts,  find a motor at the junkyard and just get some  oil pan bolts,  same bolt
