Ready Welder
Started by jrock, July 13, 2009, 05:34:46 PM
jrock
What do do you think of them and are they worth the cost? Trail wise I would think a few sticks would be better and at home you could get a better welder for the same cost.  :twocents:
http://www.readywelder.com/catalog/index.php?cPath=21
snowshoebrue
i have one and it is bad arse.  plus you can use it as a spool gun to weld aluminum or stainless at home if you wanted to.  the cool thing about a ready welder is you can take it to the broken vehicle.  with a premier you have to jockey your rig up to the broken rig.  they are kinda spendy, but handy if you need it
Blingn
He has fixed a few rigs with it
junya92toy
Well it takes at least 2 batterys to stick weld. And its pretty shade tree. If you can afford a ready welder, go for it. A safe and sound repair is the best way to get home.
i think they are cool, they are bank, but then you can't run your 220v machine on the side of the road either
junya92toy
BLACKDOG
:thumbs: very nice to have on the trail :yesnod:
              -Ronald Reagan
Quote from: jerry92toy on July 14, 2009, 08:18:54 PM
Can with a generator
yeah you can, but realistically, whos dragging a generator with them that big on their wheeling rig all the time?
fj-rankenstein
i have one and i love it...  i have honestly only used it about 10-15 times now but it is more than worth the money..  this is the best onboard welder for the buck and i cant think of anything else that comes close to it..  i  have only used it for trail fixes a couple of times but have used it for aluminum a little and the built in gas solenoid makes this not too bad of an aluminum welder..
i have run both flux core and shielded wire with gas through this gun and played with different voltages from 6 volts to 24 volts and it works pretty good with the lower voltages but works terrific with either 12 volts or 24 volts...   with flux core you can easily weld up to half inch steel and with a few passes i have done 3/4 inch as well with good results...
i dont think i would consider using this as a shop welder though...  it is a bit bulky and not super friendly on the body with long welding times... it can get a bit heavy being that the spool is in the gun itself..
if you have the money than get one.... just dont show it off at too many events or else you will end up being quite a busy man repairing other peoples junk.. :disturbed:
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
Blingn
is there any other brands that are close to this one?
*ROKTOY*
Nice write up on Pirate, highly recommend I intend to get one.
Quote from: *ROKTOY* on July 15, 2009, 01:36:08 PM
what? a nice writeup on pirate? i intend do get me one of those also ;)
j/k.... nice to see stuff like these tests being done though..
one competitor... ok should we jsut say trail gear now? jeez.......
they say they use 1035 dom, now couldnt the type effect its strength and all of that?
Blingn
there is a guy in sac area that will rewire a yota alt for a ob welder.
Dingman.
[threadjack]
For those of you that have had the alternators re wrapped to put out more amps, what does it usually cost?  and are you happy with it?
[/threadjack]
I would love to get a welder for the trail, because it would be a good piece to have, I don't know how often i would use it but for those of us who don't want to spend that much money, i cannot see the reason why to not carry a few welding rods and a set of jumper cables.   At least it may be an option to get you home.  Regardless, i think it would be a good idea to have one or the other.
Quote from: Blingn on July 15, 2009, 02:08:53 PM
doh! should have kept my old one i sold for $20
BirdDog
I have $1000.00 in a Mobi-Arc 200x. I've had it in & out of my vehicle 4 times. So far it has been nothing but a headache. I will say the guys at Mobi-Arc have always called right back & have been real helpful , no complaints about their customer service. I just wish I didn't need them so often.
I have approx. $600.00 in a Mech Man 200 amp Alternator which has performed flawlessly.
If I could do it all over again I would probably just go with the Ready Welder.
Toymin8r
You can find Ready Welder II's on Ebay resonably priced sometimes.   I bought mine that way last week for $180.   The case looked a little beat up from being in a truck but I don't think the welder had ever actually been used.  All the parts looked brand new.   :beerchug:
jrock
Toymin8r
Quote from: jrock on August 02, 2009, 07:38:25 AM
Was that Willy's?
No, the auction ended on the one I bought 3 days later his did.   He got $350 for his.  :yikes:   The only difference is that the one I bought didn't actually say it was new. :dunno:
jrock
 :thumbs: If I can find a deal like that I will buy one.  :crossed:
Toymin8r
jrock
AHhhhhhhhhhh! are you joking! I just spent all my coin on histeer when I could have gotten a welder. Now I have nothing to spend, damn.  :smack:
