Author Topic: Half Doors  (Read 1378 times)
To The Floor
  • Turtle Points: 220
  • Male Posts: 393
  • Member since Jul '04
  • THE KRAK
Half Doors
« on: Oct 18, 2004, 10:45:43 PM »
I am building some half doors that look similar to Marlins. I have everything figured out minus what do about the door latch.  I have seen like Hyena, where he just hooked up a wire that you can pull.  But I want to see some other ideas, like maybe use the stock latch and have it mounted horizontal in the little "arm rest" section instead of vertical on the door.  I wanna do something that looks professional because this truck has to represent the work I do.  It's going to be a TTF Fabrication shop truck so I want to do unique stuff to represent the shop.
To The Floor [OP]
  • Male Posts: 393
  • THE KRAK
Re: Half Doors
« Reply #1 on: Oct 19, 2004, 11:31:26 AM »
I got one door cut to shapel, and I found a much more simple way to have a door latch.  I am going to weld on a piece of 1/4" rod to the existing latch sticking out so I can just push down on it and the door will open.  I just need to cut the passenger side door now and then weld in the sheet metal.  Pictures soon!
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Re: Half Doors
« Reply #2 on: Oct 19, 2004, 04:13:16 PM »
If you cut the back part low enough you don't have to make anything.  you can just push the latch down and it will open.  I have 3 firends who did that and still use.  I wanted to do something different though.
Marketing
  • Turtle Points: -30
  • Male Posts: 1,639
  • Member since Aug '03
Re: Half Doors
« Reply #3 on: Oct 19, 2004, 10:14:20 PM »
Marlin's doors just have a small button on the factory latch rod. Just push down and the door pops open like a factory setup.
Last post Feb 16, 2013, 07:56:43 PM
by gmack192
Last post Mar 30, 2005, 08:29:33 PM
by wmflyfisher
Last post Jun 30, 2006, 04:22:47 PM
by toynizzy
Last post Aug 20, 2006, 10:23:54 PM
by ladderrack guy
Last post Oct 18, 2006, 09:22:28 AM
by sloyota
