Author Topic: EFI on a 80' hybrid ???  (Read 3062 times)
llamas
  • Male Posts: 142
  • Member since Sep '08
« on: Jun 20, 2009, 05:41:48 AM »
Is anybody  on here run a 22r/20r hybrid with EFI ??  I'm currently running 32/36 weber P O S if you know what I mean... I thought I read somewhere on here someone put EFI from an early celica, but I'm afflicted with CRS.
 any help would be goood thanks :dunno: :hammerhead:
don whitman
Re: EFI on a 80' hybrid ???
« Reply #1 on: Jun 20, 2009, 07:56:01 AM »
the early celicas did have efi on the "early" style 22R head, but it wont work on a 20R head unless you do some MAJOR porting and hole drilling on the 20R head and the efi intake
now you could find a 90-95 4 cylinder chevy engine with the TBI injection and do that
although i think you would need a custom adapter to attach it to the 20R intake
llamas [OP]
  • Male Posts: 142
« Reply #2 on: Jun 20, 2009, 08:17:13 AM »
Do you have a hybrid ? if so what carb ? maybe I should just change carbs???
don whitman
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #3 on: Jun 21, 2009, 12:12:10 AM »
Get the LC engineering adapter and run a 22r carb on the 20r intake manifold, it'll work well.  I have a weber 32/36 on my hybrid and don't care for it at all.
And I don't have a link, but I have a thread floating around from a few years ago about efi on a hybrid/20r intake  :thumbs:
llamas [OP]
  • Male Posts: 142
« Reply #4 on: Jun 21, 2009, 05:14:57 AM »
Are you still running the weber ?  Amen on the weber , it is a POS
don whitman
  • Male Posts: 9,757
« Reply #5 on: Jun 22, 2009, 12:02:26 AM »
Unfortunately yes.  If I thought I was going to run a carb or 4 banger for a long time I'd buy the lc adapter and rebuild a 22r carb, but I'm hoping to eventually go efi, swap in a buick v6 and maybe even inject it.
llamas [OP]
  • Male Posts: 142
« Reply #6 on: Jun 22, 2009, 05:34:46 AM »
I'll call LCE this am and ask what they recomend , I don't have a problem with a stock 22r carb if it will supply enough fuel. The main problem with the weber is , after a trip to town 25mi. one way on restarting it floods bad. I took it to a shop pressure tested system 1.5-2 psi
with after market e pump , adjusted float, blah blah still floods , but it runs like a brass balled cat till you try to restart.
don whitman
THE ROCK
  • Male Posts: 219
  • Member since Apr '07
« Reply #7 on: Jun 25, 2009, 09:30:17 PM »
I run a 38dgas  weber, starts fine, runs like a raped ape on the road, runs like :pokinit: when off camber/ crawling though :smack:
llamas [OP]
  • Male Posts: 142
« Reply #8 on: Jun 26, 2009, 05:31:10 AM »
I called LCE , they said float might be a little high and I might neeed a shut off solenoid that fits on or in the carb. THe newer carbs don't need them , so I'm still workin on it.
don whitman
  • Male Posts: 9,757
« Reply #9 on: Jun 26, 2009, 10:26:07 PM »
Are you pumping it?  I only pump the gas on a cold start on mine, the rest of the day I just turn the key and it starts in about 1/2 second pretty much every time.  This is for warm weather though.
llamas [OP]
  • Male Posts: 142
« Reply #10 on: Jun 27, 2009, 05:27:10 AM »
No pumping..but if it does not start after a few seconds of trying to start then put my foot to the floor and a'few' seconds later it starts and pukes black unburned fuel, after I blo out all the crap it runs idles perfect..?
don whitman
Last post Sep 05, 2004, 02:29:03 PM
by Marlin
20/22r hybrid
Last post Mar 15, 2015, 08:33:07 PM
by zippo
Last post May 15, 2005, 02:20:49 PM
by kneedownnate
Last post Mar 15, 2015, 01:17:41 PM
by SloCrawler
Last post Apr 08, 2011, 03:57:23 PM
by yotaneck13
