Don't you give the flashlight to your girlfriend and tell her to get out of the truck?
If you stayed at moon rocks past dark you probably wouldnt have this question! hahaha But they look good!
Here you go
I'll have to snap some pics when I get home but I just used 55 watt "tractor" lights. There is one mounted above the front driveline pointed at the front diff, one under the rear driveline mounted to the crossmember pointing at the rear diff, one on each side behind the front body mounts pointed down, one by the radiator and one above the rear axle both pointing down.One thing that drives me nuts is visible rocklights, not only is it annoying to me as a driver to have lights pointing out all over the place on my buddies trucks but it is tougher on the spotter to have lights blinding you causing your vision to dim in the light.
ill have to take some pics of mine, i just mounted 4 lights on my 4runner, 2 under the doors and 2 on the shock hoops
What about putting some right in front of your rear wheels?
Im still gonna add 2 more under the Runner in front of back tires
now PAY ATTENTION
If you want high output out of an led, you have to build your own.Link> http://www.pirate4x4.com/forum/showthread.php?t=798604
Looks awesome, But are there headlights shinning on it also?
Started by Hyena « 1 2 » Project Research and Build-Ups
Started by rockhound Project Research and Build-Ups
Started by 12GA.YOTA « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by H8PVMNT « 1 2 » General 4WD Discussion
Started by rockin86runner General 4WD Discussion
